Postby rern » 04 Sep 2017, 17:09
Re: Addons Menu - Install addons the easy way
Postby R101 » 04 Sep 2017, 19:02
Brilliant! Thanks rern.
Addons Menu installed OK, but when I try to install any of the options I get the message " sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set ".
Also, I have previously expanded the partition and installed enhancements. Should I run these options anyway to get the menu to sync, or could that do damage?
Postby rern » 05 Sep 2017, 01:32
Postby R101 » 05 Sep 2017, 10:02
Thanks, permissions were -rwxr and that has fixed it.
Would it be possible to have a notification that an install has completed?
Postby rern » 09 Sep 2017, 05:14
Postby R101 » 09 Sep 2017, 11:05
rern,
I have re-installed the addons and enhancements packages without any problem, and it all seems to be working well. Will it be possible to do future kernel updates from this menu too?
It's great that you keep Rune moving forward while also making it easy to hide unused features, which is what makes Rune superior to its less purist siblings.
Thanks,
R.
Postby tuna » 13 Sep 2017, 21:51
How would one develop an 'addon' for this module, as the youtube addon could benefit from it :D
tuna
Postby R101 » 14 Sep 2017, 09:52
rern,
I have accidentally discovered that with no volume control or cover display, touching top right, below the menu icon, leaves me with just the progress indicator in the middle of the play screen. I cannot find any reference to this in the forum and assume it is part of your enhancement package?
This result is just the layout I want, but it is easy to cancel it when aiming for the menu icon. Is there a way to lock this feature?
Postby rern » 14 Sep 2017, 12:05
Postby R101 » 14 Sep 2017, 17:00
