Audio buffer
Audio buffer
Postby pistollero » 16 May 2015, 07:45
Hello, yesterday i tried to increase the audio buffer to 131072 and after that only spotify works, everything else dont work. Example when select usb, the spining wheel doesn t stop. On the radios the same thing. I reduced to 65536 and everything was back to normal.
Can anyone help me?
I m using pi2
pistollero
Re: Audio buffer
Postby hondagx35 » 16 May 2015, 21:57
Re: Audio buffer
Postby pistollero » 16 May 2015, 23:20
I think with the bigger buffer sounds better.
By the way, if spotify doesn t use mpd, what it use?
pistollero
Re: Audio buffer
Postby ACX » 18 May 2015, 00:48
Re: Audio buffer
Postby pistollero » 18 May 2015, 08:12
I have three DACs, HiFiBerry DAC + , Durio sound pro and mamboberry and tested all three with 512, 1024, 2048, 4096... And so on. From 8192 the soundstage seems wider. But that is just my opinion.
pistollero
Re: Audio buffer
Postby pistollero » 18 May 2015, 08:15
I m using Orion v2 , to my ears sounds better than the rest
pistollero
Re: Audio buffer
Postby pistollero » 18 May 2015, 08:16
On RPI 2
pistollero
Re: Audio buffer
Postby pistollero » 18 May 2015, 21:24
Ok ACX i testing 512 i think is the minimum . It sounds diferent. But i would like to know what others think and use.
pistollero
Re: Audio buffer
Postby ACX » 19 May 2015, 01:30
Re: Audio buffer
Postby rastus » 23 May 2016, 16:10
rastus
