Digi+ , Rune and USB drive = channel swapping
Postby piknik » 06 May 2016, 02:23
Currently having an issue when playing a file (FLAC), the channels will swap several times during a song. Sometimes it's very subtle, while other times it's quite jarring. The issue only occurs when accessing a mounted USB drive source. When accessing a network mounted source, the files play perfectly.
Hardware: RPi3 with Hifiberry Digi+ board. USB powered Toshiba Canvio Connect hard drive and Canakit 5V 2.5A p.s.
Software: beta 4 image (03212016)
This issue has been discussed at the Hifiberry forum
https://support.hifiberry.com/hc/en-us/ ... nd-DAC-Pro
and here, but pertaining to the DAC Pro boards, not the Digi+.
pi3-and-dac-pro-t3293-60.html
Has RuneAudio been able to duplicate this issue, and if so, is RuneAudio also working with Hifiberry on a fix. It sounds like it's a kernel issue and Hifiberry folks are in touch with the Volumio people, so hopefully parallel efforts are going on here.
Thanks and great product.
piknik
Re: Digi+ , Rune and USB drive = channel swapping
Postby hondagx35 » 06 May 2016, 13:35
Postby piknik » 06 May 2016, 20:54
Bingo! That did it.
After doing your suggested changes and listening for a couple of hours, I haven't heard the channel swapping at all...not even once. I am ecstatic. And to top it off, I can use the full capacity of my mSD card now. :)
Frank, thanks so much for your quick help, very much appreciated.
piknik
Postby rastus » 06 May 2016, 23:51
So, can these instructions be used with the Raspberry Pi 2B and DAC+, or is this specific to the Raspberry Pi 3 and DIGI+?
rastus
Postby hondagx35 » 07 May 2016, 06:53
as both (RP2/RP3) share the same image this should work.
Postby rastus » 07 May 2016, 07:01
hondagx35 > Thank you.
rastus
Postby rastus » 09 May 2016, 01:39
rastus
Postby hondagx35 » 09 May 2016, 05:57
Postby rastus » 09 May 2016, 08:35
rastus
Postby Dohmar » 12 May 2016, 11:54
Dohmar
Users browsing this forum: Google [Bot] and 7 guests
