disable timeknob and coverart if webradio
Postby waves » 15 Jan 2015, 09:21
waves
Re: disable timeknob and coverart if webradio
Postby ACX » 15 Jan 2015, 14:57
Postby ACX » 15 Jan 2015, 15:50
Oh, I forgot that you have to minify the file into this one
https://github.com/RuneAudio/RuneUI/blo ... eui.min.js
after the mod.
Postby waves » 15 Jan 2015, 20:48
Thanks, I'll give that a try and report back here later. I've been poking around the code and that js file already tried out a few modifications. Mostly disabling stuff to make the UI even more minimal. That is one great thing with local server/browser software - users can jump right in and start change things up on their local install very easily. (... and also break things. But reinstalls are cheap :)
waves
Postby waves » 16 Jan 2015, 13:58
I'm new to javascript compression. I did a quick test with http://jscompress.com/ but RA then seems to overwrite the resulting runeui.min.js file on boot with a default one. What tool should I use to minify?
Once I've figured out minify I will try these commands:
$('#timeknob').addClass('hide');
$('#timeknob').removeClass('hide');
waves
Postby waves » 16 Jan 2015, 16:14
waves
Postby ACX » 16 Jan 2015, 20:28
Yes. Have you managed to get the desired result?
Postby waves » 16 Jan 2015, 22:02
Yes! The above edits to runeui.js + minifying did the trick. The timeknob and coverart are autohidden when playing a stream and autoshown again when playing a file from usb storage.
Not that using the online minify tool is any problem or anything but just out of curiousity is there a command line tool bundled with RuneAudio for minifying?
waves
Postby ACX » 17 Jan 2015, 03:55
I use UglifyJS with Grunt to automate the process on every edit.
If you want to perform that manually, here's a online tool:
https://marijnhaverbeke.nl/uglifyjs
Postby robertinjo » 19 Jan 2015, 20:57
robertinjo
