Hardware volume control not working
Re: Hardware volume control not working
Postby jlynton » 01 Oct 2018, 16:30
I have the same problem,Hardware volume control not working. Debug info here: https://pastebin.com/pys8AbCU
I can move the rotary volume control, and it stays wherever I leave it, but does not adjust the volume, which always stays at 100.
Hope you can help, many thanks
Jeremy
jlynton
Postby hondagx35 » 01 Oct 2018, 16:51
Postby jlynton » 01 Oct 2018, 17:08
Hello Frank,
I went to /etc/mpd.conf and saw a warning NOT to edit it manually, so I went to the MPD config section of the UI, but cannot find anywhere to change it.
Am I missing something, or should I go ahead and edit it manually?
Many thanks,
Jeremy
[edit] I went ahead and manually edited /etc/mpd.conf, after a reboot the entry in mpd.conf had reset itself from Digital to PCM. So it didn't help.[/edit]
jlynton
Postby janui » 01 Oct 2018, 21:00
Postby jlynton » 02 Oct 2018, 09:30
Good morning Janui,
I followed your excellent instructions, and it is now working perfectly!
Thank you so much for your help, I am so happy now I have my beloved RuneAudio back! And thank you also for all the great work that you do for this wonderful system.
Kind regards, Jeremy
jlynton
Postby janui » 02 Oct 2018, 10:47
Hi jlynton,
Thanks for the testing and the feedback. I will include this change as soon as possible in the distribution code.
Postby jlynton » 02 Oct 2018, 18:41
jlynton
Postby konki » 02 Apr 2019, 20:39
konki
Postby janui » 03 Apr 2019, 10:39
Postby konki » 08 Apr 2019, 19:52
Thank you again for your answer, the hardware volume control never worked with my arcam rDac, I was hoping for an incorrect configuration of MDP ...
konki
konki
