Missed all the non-english folder/files
Postby syklab » 02 Mar 2014, 10:45
Able to install v0.2 on the BBB and making music, just ran into one problem when updating MPD database, database is pointing to a Synology 214play NAS, connection is via SMB/CIFS. I use the browse function to list out all the music folder from my NAS, everything with non english character file name and folder name were disappeared. I went into the advance option under Database and try to change the charset but only ISO 8859-1 is available, does it support any character set other than english ? How can I fix this?
syklab
Re: Missed all the non-english folder/files
Postby ACX » 02 Mar 2014, 15:50
Hi skylab, it's because of , we are going to solve it in the next version. In the meanwhile I suggest you to use NFS protocol (it should perform better too).
Postby syklab » 02 Mar 2014, 17:51
Just switched to use NFS and seems to be working, will the next release include driver for I2S output?
syklab
Postby ACX » 02 Mar 2014, 18:31
Postby will » 15 May 2014, 14:12
will
Postby ACX » 15 May 2014, 15:07
Hi will, I currently use a Synology DS214 to host my music library and it works flawlessly via NFS. How are you trying to mount it?
Postby will » 15 May 2014, 16:03
will
Postby ACX » 15 May 2014, 17:23
Try with volume1/music/RaspyFi as Remote directory.
Did you give NFS permissions to your device's IP address?
Postby will » 16 May 2014, 16:07
will
Postby ACX » 18 May 2014, 21:42
Return to Beaglebone Black
