Mount not responding problem!
Postby dror » 13 Jul 2016, 14:14
After fixing my previous mounting problem after updating (that was: guess access is not permitted on PC side. even though my PC user has no password set it is needed to set the mount to login with user name but leave password BLANK), I know facing the same problem which was the reason for updating (hoped update would solved it):
After rebooting Rune is fine and all. Playing , Wifi AP is working and so... but after I come back after some time, the UI is not responding (Wifi OK and my smartphone can connect to it and use internet). Logging with MPDroid I can see the mount and I can even add files to playlist, but when pressing "PLAY" button nothing happens - it looks like it is pressed playback doesn't start. As I said - the web interface through the browser is not even loading.
Thanks in advance
Dror
edit: ssh login also works
dror
Re: Mount not responding problem!
Postby dror » 14 Jul 2016, 21:05
dror
Postby dror » 19 Jul 2016, 12:01
Can I give any output which can help debugging this?
Could this be a UI issue? (it is not responsive either - buttons can be pressed but do nothing)
Any bash command to test mount response? ssh logging is working.
thanks
Dror
dror
Postby hondagx35 » 19 Jul 2016, 17:49
Postby dror » 19 Jul 2016, 18:35
dror
Postby dror » 19 Jul 2016, 18:51
So after ~7 min from pressing the debug button, the page loaded:
systemctl still shows the same two services as failed
dror
Postby hondagx35 » 19 Jul 2016, 20:36
Postby dror » 19 Jul 2016, 20:45
Indeed it is an old image (maybe fetched it a year ago), which I have updated with the instructions of how to update (nightly) + kernel update. No system pacmans as far as I remember.
I started with a fresh one too, but with the new one I couldn't make the AP to work as I want (it is a must for me). I get an AP but without internet sharing through the Ethernet. I'm trying to stick with the working image.
how can I make those services run? (do I need them?)
dror
Postby hondagx35 » 19 Jul 2016, 20:58
Postby dror » 29 Jul 2016, 11:28
dror
