Pi2 OS update breaks rune
Postby gearhead » 30 May 2015, 15:45
gearhead
Re: Pi2 OS update breaks rune
Postby hondagx35 » 30 May 2015, 16:36
Postby gearhead » 30 May 2015, 17:55
Frank, Maybe it would be better to ask for your help in what I am trying to do, then...
What I want to experiment with is Jack2, specifically Jack2-net played through the i2s card. The kernel, at least on the PiB+, does not support the i2s as mmap is not enabled. There is a guy that has patched the kernel so that mmap will work with the i2s driver. I tried it with my piB+ and got no output, though it appeared to be 'connected' via jack. I want to try this with the B2 as that is what he was using. The link where I found the info is here (his diff to the kernel is there as well):
https://www.raspberrypi.org/forums/view ... p&start=50
I'd like to have jack2 working so I can test out a few things, but it does not appear that this is in the kernel. will have to try it again after I reinstall the Pi2 RuneOS software... I messed it up somehow.
Keith
gearhead
Postby s33w0lf » 30 May 2015, 18:40
see here:
doing-pacman-updates-for-0-3-beta-t519.html#p6860
and here:
mpd-failed-t1194.html
If u need samba ignore pakets, not icu. Find links to mpd-rune via google
Edit: here it is https://github.com/RuneAudio/RuneOS/tre ... s/mpd-rune
U have to be familiar with ABS and AUR: https://wiki.archlinux.org/index.php/Ar ... Repository
s33w0lf
