Radio Stream Selection
Postby andfor » 28 Sep 2017, 18:54
It might just be me, but I find it annoying that Rune adds radio streams to the end of the queue when you double-click on a station in the library.
Switching between stations means that I often end up with a long list with the same station listed several times.
I think it would be better if, for radio stations only, a double-click means 'Add Replace and Play' rather than just 'Add'. That way you could switch stations easily without creating a long list in the queue.
Obviously I wouldn't want this behaviour to apply to choosing music from the attached music library.
Maybe this would be more complicated to achieve than I realise, but some help with how to achieve this by editing the code would be appreciated if at all possible without breaking the whole thing!
andfor
Re: Radio Stream Selection
Postby hondagx35 » 28 Sep 2017, 22:10
Postby andfor » 30 Sep 2017, 09:41
Thanks that worked great.
This might be greedy of me, but is there a way to do this with a single click? I've tried adding the code you gave me to the library browsing code above the section you altered in various places, but I'm not savvy enough to know what I'm doing really.
Think of all the time I could save by only clicking once! :D That's a huge increase in UI efficiency.
Thanks again.
andfor
Postby hondagx35 » 30 Sep 2017, 10:52
Postby andfor » 01 Oct 2017, 09:45
Thanks Frank!
That works.
andfor
