Raspberry pi with 3.2 TFT Screen
Postby drejc » 09 Feb 2017, 15:48
drejc
Re: Raspberry pi with 3.2 TFT Screen
Postby hondagx35 » 09 Feb 2017, 18:05
Hi drejc,
you have to switch the output to the correct framebuffer.
See .
Postby drejc » 09 Feb 2017, 22:52
The link you gave is for setting up the TFT screen. Not sure to which part you are referencing as it is a long post.
But setting up the 3.2 screen is not my problem ... the screen works fine ... I can see the terminal and I can do the calibration ... etc.
The problem is that the RuneAudio UI that previously loaded on boot to the HDMI screen now stays in terminal mode on the TFT.
So please point me to the correct location in the post ... or maybe I am missing something.
PS: The given post references the Rasbian distribution, but RuneAudio is based on Arch linux.
drejc
Postby Yatsushiro » 10 Feb 2017, 08:41
Yatsushiro
Postby drejc » 10 Feb 2017, 08:49
drejc
Postby drejc » 10 Feb 2017, 09:01
drejc
Postby drejc » 10 Feb 2017, 09:07
drejc
Postby hondagx35 » 10 Feb 2017, 09:34
Postby Yatsushiro » 10 Feb 2017, 09:37
I'd also look at installing Rerns UI updates, with some features and options that should mak eit work better on smaller screens:
runeui-enhancement-t4207.html
Yatsushiro
Postby drejc » 10 Feb 2017, 10:01
Cool will definitely play around with it, but with a 320x240 touchscreen you are really limited. And touch with fingers needs large target areas.
Apart from that it might be a good idea to make on UI with only basic controls (limited for really small screens)
In my case I would only need a play/pause button, play queue, volume control and power off, as I intend to use this screen only for basic controls.
Other things can be adjusted on a proper screen, or via smart-phone.
If someone can point me to the correct PHP, CSS and JavaScript files I can give it a try.
drejc
Users browsing this forum: Bing [Bot] and 19 guests
