Raspberry Pi Zero Support in 0.4
Re: Raspberry Pi Zero Support in 0.4
Postby McAllister » 10 Mar 2017, 20:53
McAllister
Postby rlsten » 10 Mar 2017, 21:50
rlsten
Postby rawdevice » 10 Mar 2017, 22:16
rawdevice
Postby rlsten » 11 Mar 2017, 15:03
rlsten
Postby janui » 31 Mar 2017, 17:52
Postby rlsten » 31 Mar 2017, 22:37
rlsten
Postby delboy711 » 25 Apr 2017, 13:08
delboy711
Postby janui » 05 May 2017, 20:40
Thanks for the feedback delboy711,
The typo in the player name could have been worse by missing out the "n" :D
I have followed your instructions and published a new image, info here: raspberry-pi-zero-support-in-0-4-t3711-70.html#p20577
All additional feedback welcome,
Janui
Postby arakis » 13 May 2017, 17:19
PI Zero W & HiFiBerry DAC+ Zero
arakis
Postby theskyentist » 28 May 2017, 00:13
I am having some difficulties setting this up, so hopefully someone more experienced can help me.
I am using the image posted on a pi zero v1.3 (not w, so with a wifi module), and when tested without changing the initial config text, literally taking the written SD card from computer to pi, I was able to stream spotify both with ethernet and wifi. The RuneUI would then become inaccessible after about 10-15 mins, although I could still SSH from my laptop. When updated with the given config text for turbo I could access the UI, but could not play any music, and again I could not access the UI after about 10 mins. As well, I could not SSH.
Any advice for troubleshooting would be greatly appreciated.
I am using a Trond model AC2 usb audio adapter, no display, realtek wireless module if that helps.
theskyentist
