[MOD]Replace shairport with shairport-sync (ios 9 compatibil
Postby nullomorph » 30 Sep 2015, 18:36
nullomorph
Re: [MOD]Replace shairport with shairport-sync (ios 9 compat
Postby chuchuj » 14 Oct 2015, 22:42
I tried this tonight and shairplay-sync would not start. Can you share your configure file?
Thanks :D
chuchuj
Postby nullomorph » 16 Oct 2015, 16:52
nullomorph
Postby hansh64 » 06 Nov 2015, 14:36
Hi nullomorph,
Question: do I have to disable Airplay in the RuneUI? Is shairplay-sync an addition to the installed airplay or will it interfere with the installed feature?
Edit: ...I should read your step by step instructions...it's the first step...(stupid me) :?
hansh64
Postby popov » 09 Dec 2015, 23:30
popov
Postby bone330 » 22 Dec 2015, 21:28
I second the recommendation to switch to shairport-sync for use with iOS 9 devices. Works much better that way for me.
bone330
Postby hansh64 » 20 Jan 2016, 12:45
Running shairport-sync using HifiBerry Digi+ (S/PDIF) or HDMI runs great. However trying to run it over USB to my USB DAC produces garbled sound or no sound at all.
Any thoughts?
Thanks,
Hans.
hansh64
Postby popov » 01 Mar 2016, 15:56
popov
Postby daymz » 14 Dec 2017, 15:08
Unfortunately, this update is no longer possible for Raspberry Pi 1 devices.
The current version of Shairport-Sync (as built in the repo) doesn't work with RuneAudio's ArchLinux version and libraries.
Because ArchLinux (the OS over which RuneAudio is built) uses a Rolling window for its repos, it's not possible to install an older version of Shairport-Sync, and doing a system-wide update (pacman -Syu) will break the entire installation (I even tried blocking all firmware- and raspberry-related updates).
And there hasn't been any update to RuneAudio for Rpi in over 3 years so I guess this is a dead issue.
Just wanted to give a heads-up to whoever may want to try this.
If you need Shairport-Sync like I do, I'm afraid you will have to look at another system. Bummer, I really love RuneAudio. I'll take a look at Pi MusicBox, seems to be a potentially interesting replacement.
EDIT: specified the update procedure doesn't work for Raspberry Pi 1, as janui and I found out later in the thread. I don't want readers to be misled by my original comment.
daymz
Postby janui » 14 Dec 2017, 17:59
