Rpi3 + Screen 3,5 Kedei + Runeaudio
Postby dom_france » 09 Mar 2018, 17:02
I need your help for my screen :
https://fr.aliexpress.com/item/Best-Pri ... 0.0.pHfkDV
I see this topics :
waveshare-spotspear-3-5-touch-screen-working-with-rune-t3859.html
A lots of information for me, but I have a screen : modele 3'5 Kedei.
The driver is available :
http://kedei.net/raspberry/raspberry.html
How to do ?
I'm blocked......
Thank you
DOM
dom_france
Re: Rpi3 + Screen 3,5 Kedei + Runeaudio
Postby Urlin » 10 Mar 2018, 16:37
Файлы.7z
(1.18 KiB) Downloaded 4957 times
Urlin
Postby dom_france » 10 Mar 2018, 19:09
dom_france
Postby Urlin » 10 Mar 2018, 20:51
Instruction "http://www.runeaudio.com/forum/waveshare-spotspear-3-5-touch-screen-working-with-rune-t3859.html" works only on version " RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB.img". On the version "RuneAudio_rp2_rp3_0.4-beta_20170229_2GB.img" do according to my instructions. The driver "fbturbo" should not be put. There is a driver "fbdev", it is enough. Try to copy the file "99-fbdev.conf " and " 99-calibration.conf " to the usr/share/x11/xorg folder.conf.d. In / boot / config.txt add only my text if you put " startx,..." it won't start. Instead of driver " waveshare35a.dtb " put your own. Only change to /boot / config.txt "dtoverlay=waveshare35a" to " overlay=your driver"
Urlin
Postby dom_france » 10 Mar 2018, 20:54
Hello, just pour Information, my screen work with raspian : (I just did this test to dismiss a hardware problem)
No good for the moment with runeaudio (Archlinux) :
With Archlinux (runeaudio), it's very difficult for me to understand the problem...
thank you
DOM
feature of my screen :
dom_france
Postby Urlin » 10 Mar 2018, 21:16
You have the version RuneAudio ? Which version do you use?
Urlin
Postby dom_france » 10 Mar 2018, 21:50
version 0.4b (20170229) :
dom_france
Postby Urlin » 11 Mar 2018, 07:36
I have the same version, everything works. Just follow my instructions. Please send here your file "cmdline" and "config".
View more here .
Urlin
Postby dom_france » 11 Mar 2018, 08:45
dom_france
Postby Urlin » 11 Mar 2018, 09:45
Instead, " dtoverlay=waveshare35a "should be"dtoverlay=your driver's name". Send your driver "LCD_show_v6_1_3.tar " is a file with an extension .dtb or .dtbo
Urlin
