Rune0.5 + RuneUIe (Pre-installed)
Postby rern » 09 Jul 2019, 11:22
Re: Rune0.5 + RuneUIe (Pre-installed)
Postby s.k. » 09 Jul 2019, 13:04
Hi Rern,
Thank you very much for this update.
I shall try it as soon as possible.
I need some clarifications regarding the USB thumb drive for the extra directories.
My library is on a NAS drive and after the db creation, locally (in the SD card) are present directories like the playlists, webradios etc.
How I can “transfer” all this to the new image ?
I have to copy the existing directories like the “playlists”, webradios” etc to the usb drive ?
If the above is correct, the Usb drive must have a specific name ?
What are the exact names of all the extra directories that I can copy?
Thanks in advance
Stavros
s.k.
Postby rern » 09 Jul 2019, 13:41
Postby s.k. » 09 Jul 2019, 13:46
s.k.
Postby R101 » 09 Jul 2019, 14:57
Hi rern,
Thanks for this - it's a big step forward. I gave it a try, but won't be adopting it until it does m3u8 feeds. Edit: Ignore that - I just remembered you have to turn on the ffmpeg codecs!
I am using a wifi dongle on a Pi3, and found a couple of bugs:
If the onboard wifi and bt are disabled with the addon, the dongle does not work either, and re-enabling does not restore it. This is because of the rfkill command in the addon script. (If using the old Edimax dongle on 0.5, you have to blacklist unwanted drivers manually too. Rasbian blacklists them by default.)
When adding webradio stations, the OK button did not work, but the enter key did. I am not clear about how you transfer an existing Webradio folder since the import Webradio addon disappeared.
The Android app does not show icons, just an outline. It still works OK without the UIe.
Postby AndyF » 09 Jul 2019, 21:14
Hi rern,
this topic should be pinned on top of the forum - or be merged with janui's download links. This would help newbies to find the latest versions.
Anyway - thanks a lot!
Regards, Andy
AndyF
Postby R101 » 09 Jul 2019, 23:39
Hi rern,
How do you turn off the artwork in the library? On a small screen it takes up most of the display.
The option to rotate the display does not appear when the local browser is enabled, and the zoom-setting addon does not allow a custom value to be entered. I could not get the touchscreen keyboard to appear, either.
Postby rern » 10 Jul 2019, 06:21
Postby R101 » 10 Jul 2019, 10:23
Postby R101 » 10 Jul 2019, 11:09
rern,
There looks to be a problem with the samba shares. A smb.conf link is created which points to smb-dev.conf, which does not exist by default.
Users browsing this forum: No registered users and 48 guests
