Postby challenge » 30 Oct 2014, 12:38
:arrow: When the UI hangs after applying MPD settings...
ssh and type "systemctl restart rune_SY_wrk"
seems to do wonders, in a few seconds all continues working normally and it saves the new settings, no reboot needed :mrgreen:
Also I get a recursive error/segmentation fault that ends with kernel panic when trying to reboot from ssh and have to power it off the hard way.
Are there other logs apart from menu-debug?
[ 78.214183] systemd[1]: mpd.service: main process exited, code=killed, status=11/SEGV
[ 78.229484] systemd[1]: Unit mpd.service entered failed state.
EDIT: the segmentation fault was caused by corruption in the card :x
challenge
Postby metalrob » 30 Oct 2014, 12:44
Hi all!
Test revision : Now everything is working for me! Sounds good! Works great! Didn't expect that after my first experiences :mrgreen:
For everyone who has problems with wlan connection and savings under MPD:
For Edimax users: Try to enable wlan connection with another wifi stick first (logilink mini for example works) With Edimax Encryption was identified as wep in my case and I wasn't able to access 'add new profile'
After adding new profile and saving changes under 'Interface configuration' I would recommend to make a reboot. Afterwards refresh the browser with F5 then you can see the added network- click it and press 'connect'. If you see your IP adress under 'interface properties' everything is fine.
Now you are able to replace the current wifi stick with the edimax- it will work ;)
MPD savings: First choose kernel modules (i2s or not) in settings and save. Afterwards do the savings in MPD. Probably it will hang after that (spinning arrows). Then just reboot through SSH. MPD settings will show as chosen then.
After that action everything works fine for me. Congratulations to all contributers! 0.3 beta runs smooth and sounds cool!
Greetingz
metalrob
Postby metalrob » 30 Oct 2014, 12:52
Another question:
I've stored cue sheets in every album 'cause I play wav files exclusively so there's no tagging.
How can I make them visible in the library?
With mpdroid I see the cue sheet and can choose it instead of the album- so I get album covers.
When I change to rune UI then, I see the cover also there. So, if I would be able to view my cue sheets in the library, I would
have easy realized cover view.
Any hints to bring that on?
Thanks!
metalrob
Postby ACX » 30 Oct 2014, 13:01
Postby challenge » 30 Oct 2014, 13:39
lol no I didn't know about the dev page! just using runeaudio since yesterday so I didn't give a deep look at its files.
I just saw it's running on arch, so I gave a check to the services and found that.
Quite a nice page, the only problem is that when this hang happens, the dev page is useless as it's unreachable :lol:
(it stays in the "spinning wheel/connecting..." loop as all the other UI pages)
so, for this problem, you have to fallback to ssh and manually restart the worker.
challenge
Postby Fin » 30 Oct 2014, 14:23
Fin
Postby ACX » 30 Oct 2014, 14:58
Postby hondagx35 » 30 Oct 2014, 16:41
Hi ACX,
have you seen my request on GITHUB?
frank
Postby runeaudio29 » 30 Oct 2014, 17:09
Oh my......I'm disappointed :( spinning arrows :|
runeaudio29
Postby ACX » 30 Oct 2014, 17:16
