Postby ACX » 29 Oct 2014, 16:37
Postby Woodhouse » 29 Oct 2014, 17:52
Congrats on this long awaited release! Been following this on a daily basis. Great stuff.
Just curious how I will put the image on an SD when using linux. I can't seem to find the previous instruction for .2 beta. Can I just use unetbootin? I have no windows around (haven't for years) , except those in the walls of my house ;-)
Once I know the preferred way I will be happy to do a writeup in the Docs.
Edit: Just read the inspiration source. I will use that.....
Woodhouse
Postby ACX » 29 Oct 2014, 18:06
Postby Woodhouse » 29 Oct 2014, 21:21
Bumpy ride.....
Well what can I say, the implementation of features is quite great! I do however run into some trouble that is hard to debug (can't use the webinterface during my problems..). I have until now seen MPD lock up (spinning connect on the webinterface) more often then ever before (I used the apha since release and it has never caused trouble once.). Simpy changing tracks can cause it, moving through the webinterface, but especially when changing settings for MPD.
I can still log in through SSH, but issueing the reboot command has it lock up completely. Once I killed mpd with -9 and after that it did reboot normally. Conclusion that MPD tends to get stuck really bad and holds back everything.
Gotta admit, I am running this from WIFI for the first time. I see most troubles when using the TP-LINK WN725N. At least it does work for the first time on a raspberry distro put of the box, but nevertheless it seems like I have more trouble using that.
Also when using wifi (I used the edimax as well) after boot up is hasn't linked with the network drives, and doesn't appear to retry linkeing them after the network is up and running. Not a big deal when de RPI is left on.
Will probably retry from scratch.... but i'm wondering if others have similar experiences
Woodhouse
Postby bambadoo » 29 Oct 2014, 21:33
Hi all. New to this forum. Just testing the 0.3 beta.
Got the same issues as described above here.
bambadoo
Postby kwatch » 29 Oct 2014, 21:49
When I play 24 bit 192KHZ music, CPU usage is around 60 - 70% when I execute "TOP" command. Is this normal?
kwatch
Postby Aquarius » 29 Oct 2014, 21:50
-- Aquarius
Aquarius
Postby bambadoo » 29 Oct 2014, 21:57
I have one more issue..
Something is not right with DNS. I have to enter the IP in my webbrowser.
Browsing to http://runeaudio is a no go..
With Volumio it was no problem.
bambadoo
Postby Aquarius » 29 Oct 2014, 22:05
-- Aquarius
Aquarius
Postby AudioS » 29 Oct 2014, 22:08
Yes, this version have some bugs compared to 0.3 alpha:
- host name runeaudio/ is not recognized
- when I look for assigned DNS address (192.168.1.139) and try to add Sources, it freezes and doesn't want to boot again.
AudioS
