[Addon] RuneUI Enhancement
Postby makfredo » 24 Apr 2019, 11:00
makfredo
Postby AndyF » 24 Apr 2019, 20:30
AndyF
Postby AndyF » 24 Apr 2019, 20:41
... and I'll give your idea with special folders a try.
Is it possible to force them to be on SD-Card (yes, I loose them on reflash - but I have backups)?
Regards, Andy
AndyF
Postby rern » 25 Apr 2019, 01:47
Postby AndyF » 25 Apr 2019, 07:54
Hi rern,
thanks for your reply - but command shows no effect. Ownership is still mpd:audio after chown.
"real" place in filesystem is at the moment /mnt/MPD/USB/Temp/coverarts and it's on an FAT32 filesystem.
EDIT:
I changed my USB-Stick to XFS-filesystem and changed ownership as described. Now ls -l shows correct http:http - but deleting CoverArt don't delete a file in this folder.
regards, Andy
AndyF
Postby klassikmann » 26 Apr 2019, 09:43
klassikmann
Update 20190428
Postby rern » 29 Apr 2019, 02:51
Update 20190428
Add - Playlist > flash button - Consume mode - remove each song from playlist after played
Fix - unable to create 1st bookmark
Fix - unable to add/replace album to playlist in Browse By CoverArt > album view
Fix - names with double quotes in Browse By CoverArt
Fix - unable to edit thumbnails on Sort CoverArt by artist
Fix - set volume by tap
Fix - intermittent update notification
Note on disk format: Windows formatted disk, NTFS or FAT*, will have issues with extra directories: bookmarks, coverarts, webradios. They contain files which their names contain forbidden charaters in Windows. Windows will try to fix them which result in broken filenames. So from now on, those extra directories will be created on linux ext* formatted disk only.
This means if there's no ext* disk found on USB or NAS, they will be in SD card which will be gone if reflashed with no backup. Plug in a USB drive with ext* format before install will help in this situation.
Postby dynobot » 29 Apr 2019, 23:29
I noticed that with "New" installs of Rune and the UI Enhancement WiFi is knocked out as soon as I install the UI Enhancement.
For previous installs updates do not knock out my Wifi....only the new install.
This was repeated maybe 15 times with new SD cards and 3 different RPi's. Still I'd like to get someone to confirm.
Procedure:
Flash Rune;
B2: 20180903_10_runeaudio_rpib2.img.gz for the Pi 2B, 3B and 3B+ (4,600+ downloads)
http://www.mediafire.com/file/16d92z7jb ... mg.gz/file
Install the UI
for SSH terminal
CODE: SELECT ALL
wget -qN --show-progress https://github.com/rern/RuneAudio_Addon ... nstall.sh; chmod +x install.sh; ./install.sh
Apply UI
Attempt to enable WiFi = FAIL
_OR_
Flash Rune
Enable and connect to Wifi = Wifi connects
Install the UI
Reboot
Wifi does not work
dynobot
Postby rern » 30 Apr 2019, 04:16
Postby dynobot » 30 Apr 2019, 19:40
@rern
I added the information at the end of the addonsedit.sh file.
After reboot, WiFi gone... :(
At this point, I will flash another rune img and forego the UI for now. I'd imagine most people are updating there existing Rune vs. installing new images and starting fresh.
What this means is, only existing installs of Rune or wired new installs can use the UI Enhancement.
Exact procedure
New Rune img flashed and booted
Wifi connected
Install Addons
Update adonsedit.sh file
Install UI Enhancement
run ./addonsedit.sh
reboot
Wifi disconnected and shows [off/any]
dynobot
