Schiit MODI DAC
Schiit MODI DAC
Postby DustySeven » 11 Jun 2014, 19:12
Got my Schiit MODI in the mail today, works fantastic. To control volume from RUNE UI or MPD you do have to use software control.
DustySeven
Re: Schiit MODI DAC
Postby ACX » 12 Jun 2014, 11:11
Re: Schiit MODI DAC
Postby DustySeven » 19 Jun 2014, 04:09
Interesting, I have had no issues what so ever with the 0.2 beta. It sounds amazing and there is no volume, distortion or any other issues whatsoever. I am using the Orion v2 kernel on the RUNE. strange that you have had issues. I hope you find out what is causing it.
DustySeven
Re: Schiit MODI DAC
Postby ACX » 19 Jun 2014, 17:30
With 0.2-beta everything works fine because it uses an older version of kernel, the problem shows with the more recent ones. Ah, I confirm you that OrionV2 is the best kernel profile with that DAC in my experience.
Re: Schiit MODI DAC
Postby DustySeven » 14 Jul 2014, 01:02
Just tried the .3 alpha and I see what you are talking about. Such a shame that it wont work on the new kernels. I highly ask that you try to find a fix. The MODI is an amazing DAC considering its price and makes a great choice with RUNE and Raspi for a low cost great sounding system.
DustySeven
Re: Schiit MODI DAC
Postby ACX » 14 Jul 2014, 12:50
I know because I own it and I cannot use it anymore :?
Such incompatibility between Modi's firmware and newer kernels is a true pity. I hope we can find a workaround for that...
EDIT: In the next release we are going to include also the old kernel (working with Modi), because we are realizing that it's almost impossible to cover all the possible cases with a single kernel version/config. So we are going to give the possibility to switch between kernels from the RuneUI (we already set up the switch function for the Wolfson Audio Card support in the Settings screen).
Re: Schiit MODI DAC
Postby Orion » 14 Jul 2014, 12:57
We can only provide the old kernel available via Kernel Switch feature.
I will integrate it in the next upcoming v0.3-alpha build.
Bye.
- Embedded Hi-Fi music player
Orion
Re: Schiit MODI DAC
Postby DustySeven » 14 Jul 2014, 21:53
Thanks for the Reply Orion, as long as we have a way to use the MODI we are good. Cant wait to see what you guys have in store for beta release of .3
DustySeven
Re: Schiit MODI DAC
Postby Orion » 12 Aug 2014, 20:18
Orion
Re: Schiit MODI DAC
Postby cmh714 » 14 Aug 2014, 17:06
to make the setting stick between reboots edit this file:
/etc/modprobe.d/modprobe.conf
Return to Compatibility list
