The New 4-core Raspberry Pi
Postby hondagx35 » 06 Mar 2015, 13:16
Postby hondagx35 » 06 Mar 2015, 13:28
Postby Da Alchemist » 06 Mar 2015, 15:42
Thanks for MPD, installing was quite easy, mpd -V shows now pipe Output. But I stuck again, "pacman -S brutefir" shows, that brutefir is not available.....(These are the packages that are needed to compile Brutefir under Debain " build-essential flex libasound2-dev libjack2-dev libfftw3-dev") I think after 10 years "apt-get install" i have to go something deeper into Arch. :mrgreen:
Da Alchemist
Postby hondagx35 » 06 Mar 2015, 16:33
Postby unameme » 06 Mar 2015, 18:25
unameme
Postby hondagx35 » 06 Mar 2015, 19:33
Hi unameme,
/lib is now deprecated in arch linux.
I've made a symbolic link to /usr/lib on the current image,
but this seems to work not in all purposes.
The install path has to be changed, see .
Best would be to buy a wifi dongle that is supported by arch linux.
For example a cheap EDIMAX.
Postby unameme » 06 Mar 2015, 20:04
Thanks, Frank.
For now I will try to install it as in the link, but to end my constant troubles I think an Edimax is the best option.
To be sure, Edimax EW-7811Un N150 NANO is the supported one?
unameme
Postby hondagx35 » 06 Mar 2015, 22:41
Postby emilot » 06 Mar 2015, 22:47
emilot
Postby hondagx35 » 06 Mar 2015, 23:20
Hi emilot,
thank you for the report.
Users browsing this forum: No registered users and 32 guests
