Waveshare Spotspear 3.5" Touch Screen Working with Rune
Postby rlsten » 01 Aug 2016, 13:51
rlsten
Re: Waveshare Spotspear 3.5" Touch Screen Working with Rune
Postby zzeromin » 16 Aug 2016, 08:38
Hi. rlsten
Thanks for great tutorial.
I've successfully done setup 3.5" TFT LCD on RPi 3B.
You are the best.
Thanks a lot.
zzeromin
zzeromin
Postby radu022003 » 21 Aug 2016, 08:27
Hello, I also want to use RuneAudio with this LCD and RPi1 (later with RPi0). Until now I managed to make the LCD work, meaning I can see messages on LCD and console.
I followed some tutorials about how to install X on arch linux but when i run startx command is starting and immediately stopping without relevant error (at least for me).
Can you please provide some details about how to get to the RuneAudio interface on 3.5" LCD Touchscreen?
Thanks in advance.
radu022003
Postby hondagx35 » 21 Aug 2016, 13:58
Hi radu022003,
this feature (Local Browser) is only available on the new RP2/3 and ODROID C2 images.
Installing and running x on the RP1 or Zero is too much for the little device (just my 2 cents).
What i have done for the above mentioned devices is:
- install midori (webbrowser)
- install matchbox-window-manager (needed for running the browser on the frame buffer)
- start xinit on boot and display midori pointing to http://localhost
The next RP1 image will run also on RP0 and will include the Local Browser.
Postby radu022003 » 21 Aug 2016, 16:43
installing midori seems to be impossible, at least not without efforts.
[root@runeaudio lib]# pacman -S midori
resolving dependencies...
looking for inter-conflicts...
:: libgudev and libsystemd are in conflict. Remove libsystemd? [y/N]
is this a problem only for RPi1?
radu022003
Postby hondagx35 » 21 Aug 2016, 16:56
Postby radu022003 » 22 Aug 2016, 10:33
So what is your advice? Worth continuing on this path? Or should I change to raspberry pi 3?
radu022003
Postby hondagx35 » 22 Aug 2016, 22:59
Postby runemine120 » 29 Sep 2016, 01:46
Running into some issue with my project for this, did each step but still no luck. Anyway you could post pictures for each step to see exactly what i screwed up or heck even better a new iso file with the steps done already.
runemine120
Postby tyman » 29 Sep 2016, 14:32
tyman
Users browsing this forum: No registered users and 48 guests
