Wolfson Audio Card patch for RuneAudio
Re: Wolfson Audio Card patch for RuneAudio
Postby nofx » 04 Aug 2014, 11:29
nofx
Postby dryce » 06 Aug 2014, 13:11
The patch is already integrated into rune 0.3 so you don't need to apply the patch for 0.3. You do have to run the usecase script for the connection you're using though. I couldn't find the scripts in the rune file system so I copied them from the patch here.
dryce
Postby will-1 » 06 Aug 2014, 16:15
will-1
Postby nofx » 06 Aug 2014, 16:41
nofx
Postby dryce » 06 Aug 2014, 21:56
If you unzip the patch there are a bunch of scripts that tells the system which connection (such as line out, headphone, spdif, etc) to output audio to. They end in .sh You have to call the script you need via the command line.I will be able to be more specific here in a few. Just getting off work. I think the scripts are in root folder, but I'll check.
dryce
Postby dryce » 07 Aug 2014, 01:22
f
Look at pages 7-9. It explains how to use the scripts better than I ever could. On page 8 it gives the name of the use case scripts. I am attaching a file with just the use case scripts without the patch to make it easier. I'm not sure why, but they don't appear to be in the RuneAudio image.
Basically you just want to use ./ in front of the script name to execute it.
usecase.zip
use case scripts for wolfson
(13.49 KiB) Downloaded 884 times
dryce
Postby will-1 » 07 Aug 2014, 02:13
will-1
Postby dryce » 07 Aug 2014, 02:22
My pleasure. I did the very same thing when I first setup rune. I installed everything, created the image, and then spent some time trying to figure out why there was no sound. :D
dryce
Postby will-1 » 07 Aug 2014, 15:49
will-1
Postby johnbanks » 08 Aug 2014, 14:51
I've got 0.3 ALPHA running on my RPi/Wolfson and streaming via wireless from my NAS. This is what I did ....
Firstly, go to Menu > Settings and switch to the Wolfson kernel then Apply Settings and Reboot.
But here's no sound at this point until a Wolfson script is run ...
Saman’s (forum member) Wolfson version for 0.2 BETA has a directory /root/use_case_scripts so doing the same for 0.3 ALPHA ...
Using puTTY, create this directory and copy into it the file Playback_to_Lineout.sh
Now create a cron job to run this script at boot up ...
Do export EDITOR=nano
Do crontab –e and insert the following line then save & exit
@reboot ./root/use_case_scripts/Playback_to_Lineout.sh
Do systemctl enable cronie.service
Do systemctl unmask cronie.service
Do systemctl start cronie.service
Now do crontab –l to check that the cron job(s) is there
Now do systemctl status cronie to check that cronie is running
Power down properly via RuneAudio.
Fire up again ... it works ... no need to run the script via puTTy
Hope this helps
johnbanks
