0.3 beta Unable to create wireless profile
Postby chuckles » 09 Nov 2014, 04:28
I am trying to create a wireless profile, but all I see on the configuration page is the title WIFI SSID CONFIGURATION and nothing else. How am I supposed to connect to my WPA secured wifi network?
I have :
- Tried different wifi dongles
- Tried updating from github and clearing browser cache
Thanks for any insight.
chuckles
Re: 0.3 beta Unable to create wireless profile
Postby cmh714 » 09 Nov 2014, 05:23
I believe there is a "Show" button/badge, try that....
Postby chuckles » 09 Nov 2014, 16:09
What I am trying to say is that when I click on "SHOW" and "+ ADD NEW PROFILE", I am taken to a page titled "WiFi SSID CONFIGURATION". That's all there is. I assume this is where passwords etc should be input, but as I said there is nothing there.
chuckles
Postby Klausi69 » 09 Nov 2014, 16:29
I can confirm this behaviour. In my opionion, the WiFi part is the biggest problem of a very interesting version 0.3b.
As I heard, the developer will reorganise wifi. It would be great to use Runeaudio wireless. I know there are some wifi-solutions written in this forum for the last months.
Klausi69
Postby mikma » 11 Nov 2014, 15:52
I also can confirm this behavior. I cannot connect into my wireless network nor create a wireless profile.
mikma
Postby mikma » 11 Nov 2014, 16:29
After messing with wlan0 in terminal, this is how I managed to get my wireless working:
1) Login to runeaudio with terminal, do the following:
2) wpa_passphrase myESSID myPASSWD
3) copypaste the text to/etc/wpa_supplicant/wpa_supplicant.conf (delete #psk=myPASSWD -line in the wpa_supplicant.conf file)
4) wifi-menu -o
Done.
mikma
Postby huckepucke » 14 Nov 2014, 12:57
I also had same problem adding new wireless profile.
My workaround:
I found out that name of SSID was reason for blank "WiFi SSID CONFIGURATION" page.
After changing SSID name from "Fritz!Box1234" to "fb1234" (without "!") it works fine and I can add new wlan profile in WebUI.
huckepucke
Postby Klausi69 » 14 Nov 2014, 13:47
Good info. Is it possible to rename SSID again by editing network settings at runeaudio? Or do I have to keep "fb1234" in my Fritzbox router?
Gesendet von meinem Nexus 4 mit Tapatalk
Klausi69
Postby buzzer99 » 14 Nov 2014, 23:19
I can confirm. I had no luck at all getting 0.3 (alpha or beta) to connect to my new D-Link router until I changed the name of the SSID and removed any spaces (which result in % in name) or other non alpha-numeric chars. I is now working with a simply SSID of DSL2890AL.
buzzer99
Postby EvilOverlord » 01 Apr 2015, 23:38
I'm still having this problem. My SSID was "Ted", but not visible. I set my router to broadcast the SSID, but I still get the blank page. It's a 5 Ghz network, and I have an 802.11n dongle, but my 802.11 laptop uses the network just fine.
EvilOverlord
