3x powersupply for rpi
Re: 3x powersupply for rpi
Postby fboe » 13 Nov 2016, 18:37
I have used three LT1963 regulators, as described here: http://cds.linear.com/docs/en/datasheet/1963fc.pdf
And you can see the rpi scheamtic here: https://www.raspberrypi.org/documentati ... EDUCED.pdf
fboe
Postby pelliott321 » 15 Nov 2016, 03:16
Is all you need is just the 3.3 and 1.8 supplies? What was the third one for.
What did you use for the base supply
pelliott321
Postby Discovery » 16 Dec 2016, 14:53
I just want to advise that I have tried supplying 5v via GPIO pins 2 and 6, as per fboe's original suggestion, and the results were immediately apparent. There is more detail and improvements to the quality of the sound.
This has become one of those changes where I want to listen to all my music collection again because it's all sounding better.
This has to be the simplest and most cost-effective quality improvement possible! Thoroughly recommended.
Discovery
Postby Frost_dk » 16 Dec 2016, 15:17
Then you should try to go all the way, because when I did it, it was an much greater improvement than when just feeding the 5V on the GPIO. :D
Kind regards,
Rune Frost
Frost_dk
Postby pelliott321 » 16 Dec 2016, 21:44
I still wish you would provide a bit more information
You said you used three VR's what is the 3rd one for
also what was your basic DV voltage source
pelliott321
Postby fboe » 17 Dec 2016, 16:46
fboe
Postby pelliott321 » 17 Dec 2016, 17:28
Thanks that is what I needed to know
I appreciate your patience
pelliott321
Postby fboe » 17 Dec 2016, 17:34
fboe
Postby pelliott321 » 18 Dec 2016, 13:50
Well yes one more question
I went back and read the whole thread. You very clearly explain/show where to connect the 3.3 and the 1.8v supplies but what about the 5v supply.
pelliott321
Postby hondagx35 » 18 Dec 2016, 14:23
