3x powersupply for rpi
Re: 3x powersupply for rpi
Postby fboe » 16 Jul 2017, 10:17
That will be a tricky mod, because you have to disable the onboard regulator to power it with 3 x eksternal power, and then enable it with several jumpers to power it with USB.
Cheers
Fboe
fboe
Postby thanhvo31 » 31 Jul 2017, 11:31
Hi all
I intend to contact for customize Pi with low noise LT3045 on board. But minimum order size must be 1000.
Do you attend this group buy?
thanhvo31
Postby pelliott321 » 31 Jul 2017, 20:48
I'm in if the price is not too bad, do you have a quote yet
pelliott321
Postby thanhvo31 » 01 Aug 2017, 01:12
thanhvo31
Postby dror » 07 Sep 2017, 06:44
According to topic opening, a small but probebly noticable tweak would be feeding a 5V via GPIO 2 and 6.
Can I use my regular standard rpi wall supply for this?
Thanks,
Dror
dror
Postby thanhvo31 » 09 Sep 2017, 17:46
I share My setup
Just change LT1084 by LT1963 x3 supply for 3xLT3045 to pi3x4wires
thanhvo31
Postby pistollero » 10 Sep 2017, 18:45
pistollero
Postby pistollero » 10 Sep 2017, 22:23
What are the 1963 config?
7.5v 5v 3.3v ?
pistollero
Postby dror » 11 Sep 2017, 07:14
Nice share. thank you!
But again I'm asking if a regular standard rpi power supply could be used for the 2,6 GPIO pins tweak. I would try it myself if I wasn't afraid of damaging the rpi/DAC
Dror
dror
Postby fboe » 11 Sep 2017, 07:59
fboe
