3x powersupply for rpi
Re: 3x powersupply for rpi
Postby dror » 11 Sep 2017, 11:34
dror
Postby fboe » 11 Sep 2017, 12:20
fboe
Postby dror » 12 Sep 2017, 06:49
cheers
dror
Postby hkknudsen » 17 Sep 2017, 20:15
hkknudsen
Postby dror » 19 Sep 2017, 06:32
dror
Postby fboe » 19 Sep 2017, 07:14
fboe
Postby ciuffoly » 20 Sep 2017, 15:26
Do you use external usb audio interface or internal ?
ciuffoly
Postby dror » 24 Sep 2017, 06:57
dror
Postby ricky007 » 03 Dec 2017, 11:16
Hello, do I have the onboard regulator removed? or is it enough to connect the power to PP9, PP7, PP5, PP8?
greeting
Ricky
ricky007
Postby dragos_nedelcu » 05 Dec 2017, 21:12
I did something similar. Removed the regulator and 2 inductors. Almost impossible to desolder so i ripped them with a plier. The thing is so small that i ripped c4 in the process as well so i attached another cap instead of about the same size. After that i connected the 3 voltages at L1, L2 and D5. Now about the sound. I believe it needs some burn in time. After a few hrs, the soundstage is deeper, i can hear some more details on the strings, like the fine treble and something on the background that was not there. These are the +. Now the -. The low freq are a bit booming. Hope the effect will go with burn in.
dragos_nedelcu
