44.1 flac files will not play but 96kHz will ???
Postby t_gorham_iii » 27 Sep 2015, 19:11
I'm new to Rune and have it running on a RPi 2. I'm attempting to use a Dragonfly v1 with limited success. I was having no success jumping through the alsamixer hoops but noticed that when I tried to play a file after a reboot the Dragonfly logo would turn from pink to green indicating it was playing a 44.1 file but with no sound. I decided I'd download a 96 flac file and see if I could make it turn back to pink indicating it was playing a 96kHz. It both turned pink and more surprisingly played music. I can go into alsamixer, mute and unmute and the HD file mutes and unmutes.
If I play a 44.1 rip i get silence. Going into alsamixer muting and unmuting makes no difference...
Thoughts?
t_gorham_iii
Re: 44.1 flac files will not play but 96kHz will ???
Postby hondagx35 » 27 Sep 2015, 22:40
Postby t_gorham_iii » 28 Sep 2015, 21:17
This is what I see when I run your cat command. Card 0 is the onboard sound card that is not active
[root@runeaudio ~]# cat /proc/asound/card0/pcm0p/sub0/hw_params
closed
Thank you again for taking a look...TG
t_gorham_iii
Postby hondagx35 » 28 Sep 2015, 22:01
Postby t_gorham_iii » 29 Sep 2015, 00:38
I didn't realize that there were instructions for pastebin. Url is below. Thank you...Tom
http://pastebin.com/0tJaADLB
t_gorham_iii
Postby t_gorham_iii » 29 Sep 2015, 00:56
When I change the command to point to the Dragonfly, card1, and look at the results while playing files with different rates I do so that the rates change. Just as I see the Dragonfly changes color to match the rate. 96 plays music and 44.1 does not.
I see this when I'm playing a 96KHz file
[root@runeaudio ~]# cat /proc/asound/card1/pcm0p/sub0/hw_params
access: RW_INTERLEAVED
format: S24_3LE
subformat: STD
channels: 2
rate: 96000 (96000/1)
period_size: 12000
buffer_size: 48000
And this when I'm playing a 44.1 file
format: S24_3LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 5513
buffer_size: 22050
[root@runeaudio ~]#
t_gorham_iii
Users browsing this forum: Google [Bot] and 12 guests
