Access to USB attached HDD
Postby Grundgütiger » 02 Apr 2016, 18:10
Sorry to bring this up again and in a new post, but this problem drives me crazy and I don't want to completely hijack other people's forum posts.
I just can't access the USB drive that is mounted to the Raspberry Pi from the Mac's Finder. Right now I use the 0.4 version and can open the MusicStore volume. There are five folders: LocalStorage, NAS, Podcast, USB, and Webradio. Opening the USB folder shows my hard drive but in the beginning only with a minus symbol and I couldn't open it, as I didn't had the permission doing so. With the PathFinder app I could gather information about the rights I had and re-gave them those same rights, as they were the correct rights. After that I somehow was able to access the folder using the cifs command instead of plain smb. Now I can access my USB hard drive but I only have about 185 MB free space left, which is not the free space the nearly empty 1TB hard drive has. :twisted:
Grundgütiger
Re: Access to USB attached HDD
Postby hondagx35 » 02 Apr 2016, 20:53
Postby Grundgütiger » 03 Apr 2016, 08:03
Thanks, Frank!
No, according to the system there is not enough space for adding music files - I tried. I don't understand why this is such a problem, as the Mac's operating system is based on Unix. By the way, copying files to the USB drive worked with other Raspberry Pi audio solutions.
I think, I give up for now and try something else to listen to music. I guess you need to be a MS Windows user plus some kind of a coder for "easy to use" and "ready to use" Runeaudio.
It's sad, I liked Runeaudio, but I never wanted to spend so much time fiddeling with the computer stuff - I just want to listen to music (in a certain way). Also I don't want to steal so much time from others.
Cheers and thanks for everything. I really enjoyed the time being here and appreciate all the help I got.
Grundgütiger
Postby hondagx35 » 03 Apr 2016, 11:34
Postby redstars667 » 23 Jun 2016, 16:49
hi, is there any solution to this problem ? I have exactly the same issue on Windows 10. When i try to copy a folder/album at once i get this error. When i copy song by song, it works....
EDIT:
i`m using Microsofts "SyncToy" as a workarround. This tool syncs networkfolders and does this file by file....
redstars667
Postby luieq » 05 Oct 2016, 23:19
After two hours of having the same issue with internal storage MusicStore only displaying I managed to find the fix under /etc/samba/smb.conf once you make this changes dont try runeaudio.local under your network shares you will have to do the raspberry pi`s own address and you will be able to see both the external storage and the MusicStore. Hope that helps ;)
#======================= Share Definitions =======================
directory mask = 0775
create mask = 0775
[MusicStore]
comment = MPD MusicStore (/mnt/MPD)
path = /mnt/MPD/
read only = no
public = yes
follow symlinks = yes
wide links = yes
[Music]
comment = Musica (/media/usb)
path = /media/usb/
read only = no
public = yes
wide links = yes
luieq
Postby unmade » 12 Nov 2016, 13:33
How can I access /etc/samba/smb.conf? Where is that file?
unmade
