Access to USB disk via network - help!
Re: Access to USB disk via network - help!
Postby Rachel Gomez » 02 Nov 2022, 06:49
Pick the hard drive or flash drive you want to use – you can use external or portable hard drives, too – anything with a USB connection. For this, I am using a Linksys E4200 Dual-Band Wi-Fi router and a 64GB flash drive.
USB port on router
Pop it into the USB port on the back of your Wi-Fi router, and then you’ll need admin access to your router. From a computer on your network, open the browser, enter your router’s IP into a browser and enter your password; these will be the IP and password you used when initially setting up your Wi-Fi router.
Regards,
Rachel Gomez
Rachel Gomez
