I would like to revisit this, since my webradios list has grown to a point where its a PITA reloading them.
Firstly, I am no longer a coder but can still hack stuff together and understand whats going on in the various scripts. It seems like it would be easy enough to build a script to import webradios into Rune. I mean the code thats there now is reusable enough I think to do whats needed.
I think 2 use cases may exist: one for importing "new" stations, and one for importing previous Rune stations.
For the new stations a simple file with Title and URL, comma separated or something simple like that. For "old" stations, grab each .pls file, grab the Title1 and File1 value. Then populate redis either using the code already written or with a redis-cli hset command.
The code can be found in /var/www/command/rune_SY_wrk (near the bottom), which in turn uses the addRadio function located in /srv/http/apps/libs/runeaudio.php
any help appreciated, as I am trying to bash this together
probably best to just stay with php....
