Add song to saved playlist
Postby Makla » 24 Dec 2019, 10:11
Is it possible to add song to saved playlist? I can only add it to current playlist, but not saved (existing).
I am using Rasberry PI 4 and RuneAudio+R e2  20191128.
Makla
Re: Add song to saved playlist
Postby Ryan4 » 26 May 2021, 13:32
Ryan4
Postby golu121 » 22 Dec 2022, 05:33
Long press on a song. From the menu that appears, tap Add to playlist. Tap New playlist or select an existing playlist.
golu121
Postby ervinhaley » 04 Jan 2023, 10:29
Your post is amazing
ervinhaley
Postby neelyang77 » 13 Feb 2023, 13:10
neelyang77
Postby tracyberge1 » 26 Apr 2023, 10:00
tracyberge1
Postby tracyberge1 » 26 Apr 2023, 10:01
Okay thank you very much.
tracyberge1
Postby Randytucker » 05 May 2023, 11:04
When you add a song to a playlist in RuneAudio+R e2, it should give you the option to choose which playlist you want to add it to. If you're only able to add it to the current playlist and not a saved one, it's possible that you may not have created any saved playlists yet.
To create a new saved playlist in RuneAudio+R e2, you can follow these steps:
Go to the "Playlist" menu.
Click on the "Add New" button.
Enter a name for your new playlist.
Click "Save" to create the playlist.
Once you have a saved playlist, you should be able to add songs to it from the "Now Playing" screen or the "Music Library" screen. When you select a song to add, you should see a dropdown menu that allows you to choose which playlist you want to add it to.
If you're still having trouble adding songs to a saved playlist, you may want to consult the documentation for RuneAudio+R e2 or reach out to their support team for further assistance.
Randytucker
Postby marthamile » 22 Nov 2023, 11:29
marthamile
