Postby R101 » 16 Sep 2017, 12:24
Something seems to have broken. When I click Addons in the menu, I now get:
Parse error: syntax error, unexpected 'version' (T_STRING) in /srv/http/addonslog.php on line 10
Using Pi3 with Ver. 0.4b build 20170229
Postby rern » 16 Sep 2017, 16:32
Postby ianhaynes » 16 Sep 2017, 19:04
I also have the Addons menu installed 0.4b. At the moment I'm only using the Backup-Restore and Extended Fonts add ons, both of which are very welcome.
One small thing, could the links for 'Details' open in a new window (target=_blank)? I know I can right-click and do this but having it set that way would be good.
Many, many thanks for creating this functionality.
Ian
Pi 2, Ver. 0.5b, IQAudio DAC+
ianhaynes
Postby R101 » 17 Sep 2017, 09:53
Postby cmh714 » 21 Sep 2017, 16:19
Small issue with Web Radio Import...sorted properly but the "Add New" needs/should be at the top (See attachment) :) Nice job with the Add-Ons btw!!!
Postby cmh714 » 21 Sep 2017, 16:21
Backup/Restore add-on issue... I never got a prompt for storing the Backup. I havent tried to look at the script to see where it goes but would assume you should be able to stash it off Pi.
EDIT: Ok, went thru script, sort of see whats going on....for some reason it didnt work for me since there was an old backup already there, manually removed it, pressed the backup button and now have a current backup....
Postby R101 » 21 Sep 2017, 16:45
Postby rern » 21 Sep 2017, 17:04
Postby R101 » 21 Sep 2017, 17:15
Thanks - that's fixed it!
Postby R101 » 21 Sep 2017, 19:33
I have now lost the enhancements addon.
The addon menu gave the options to update or uninstall the RuneUI Enhancements. Clicking on update removed the enhancement package and I cannot find a way to get it back. I have been through the Install Addons clean up and reinstall again but the enhancement button is still labelled update rather than install. If I click on update, it tells me the enhancements are already installed, and please try update instead. If I try uninstalling, it tells me RuneUI Enhancements are not found.
