Postby rern » 14 Mar 2018, 12:24
The update badge bug was fixed.
Please run Addons Menu to update.
Postby R101 » 14 Mar 2018, 14:08
Thanks rern, it looks OK now. Useful facility, too.
Postby ianhaynes » 21 Mar 2018, 18:50
I notice from the Addons menu itself that there's an update to the Lyrics addon, but there was no red circle on the main screen indicating an update. Did this feature get removed?
Ian
Pi 2, Ver. 0.5b, IQAudio DAC+
ianhaynes
Postby rern » 22 Mar 2018, 03:49
Postby ianhaynes » 22 Mar 2018, 10:40
That doesn't work for me for some reason. Is there any debug info I can provide?
Ian
Pi 2, Ver. 0.4b build 20170229, IQAudio DAC+
ianhaynes
Postby rern » 22 Mar 2018, 12:27
Hi Ian,
Addons Menu displays update badge by:
- Check whether “bartop”, an element of RuneUI Enhancement exists.
- If it does, RuneUI Enhancement will take control of the badge . (single database access instead of twice)
- Otherwise Addons Menu manages the badge by ifself.
I assume you have installed and uninstalled RuneUI Enhancement when it still missed to remove the “bartop”. Install and uninstall again will fix it.
Try:
- Install RuneUI Enhancement
- SSH: redis-cli hset addons update 3 (Bash Command addon can run the command as well)
- Back to Playback page, the badge shows.
- Addons Menu > Back to Playback page, the badge is gone.
- Uninstall RuneUI Enhancement
- SSH the command again.
Postby ianhaynes » 22 Mar 2018, 16:19
Your assumption was right, I had installed-uninstalled the Enhancements.
Following the sequence you give has restored the Updates circle. When I ran the code the update circle initially showed 3 updates but when I openned and close the Addons menu it then correctly shows 1 update.
One odd thing, when I'd installed the Enhancements, the volume 'control' showed 'NaN' in the centre, not the volume level. When I adjusted the volume it then showed the numeric level.
Thanks for your help and thanks again for the great work you're doing with these add-ons.
Ian
ianhaynes
Postby alecs123 » 18 Apr 2018, 19:04
Hello from Mexico, 1st post here...
I installed the addons menu but I had to go back (even from scratch and make a new image).
I’m running beta 0.4; when I get the addons and graphical UI enhancements I cannot get spotify to load. I’ve tryed with and without upgrading MPD and with and without other addons like lyrics.
If I uninstall the addons altogether, then the previous interface gets all messed up especialy with library items.
Is there a work around this?
alecs123
Postby rern » 23 Apr 2018, 20:15
Hi alecs123,
I've been away for a while and will be back mid May. I can't do anything until then. May be someone could lend a hand.
Postby alecs123 » 23 Apr 2018, 20:26
Don't sorry rern, I Will wait as it's not critical and went back to b0.4 without enhancements...
alecs123
