Postby rern » 04 Aug 2018, 05:46
Postby klassikmann » 04 Aug 2018, 06:35
klassikmann
Postby rern » 04 Aug 2018, 08:28
Postby klassikmann » 04 Aug 2018, 09:14
klassikmann
Postby clriis » 04 Aug 2018, 14:16
I had to apply a new image as I suddenly could not get output (sound) and also could not access the settings menu.
As I'm having a small gathering tonight I'll wait till tomorrow until installing the Addon.
Meanwhile I got a small Q for you Rern: I just noticed that in the native image, when you choose from the list of artists and then return one step back, you are at the same point at where you left. That is sadly missing in the otherwise improved UI.
I shall return tomorrow.
clriis
Postby LeighP » 08 Aug 2018, 21:35
It seems that Addons fail to work even if installed on a fresh image on the Pi. Sad as they are good. Hope the issues can be resolved.
LeighP
LeighP
Postby MidnightExpress » 09 Aug 2018, 03:20
Regarding the recent Addons Menu problem, may it be related to github?
Having run the given command:
wget --no-check-certificate https://github.com/rern/RuneAudio/raw/m ... /reset.sh; chmod +x reset.sh; ./reset.sh
I have the naive webpage back. However, when I try for kernel update from ssh:
cd /srv/http
git pull
it returns - "fatal: Not a git repository (or any of the parent directories): .git"
Something on github side may have changed after Microsoft's acquisition.
Just a guess.
Arthur
Pi3b+, Ver. Experimental Beta 0.5 20180903, ES9018K2M Dac
MidnightExpress
Postby MidnightExpress » 09 Aug 2018, 03:35
MidnightExpress
Postby MidnightExpress » 09 Aug 2018, 03:45
Having run rern's command script, I reset the Addons Menu and have the naive webpage back.
However, when I try to have kernel update from ssh, the "git pull" command returns
Something on github side may have changed after Microsoft's acquisition. Just a guess.
Arthur
MidnightExpress
Postby rern » 09 Aug 2018, 05:41
Update 20180808
Since the browsers cache issue has rendered Addons on some devices unuseable. I've just found a solution exacly for this. It's cache busting and it turns out RuneAudio already has this feature installed, Asset extention by Plates.
This 20180808 update has utilized this cache busting and should fix most of the cache issues. Clear Browser Cache should be no longer needed after the update.
Please update and report the result.
