Postby Ripa » 27 Aug 2018, 10:19
Hi Rern,
everything seems to work perfect now.
is there a way to switch update off i have make an back up.
that way i first test the new version before i change the update.
thanks man for all the work...
Ripa
Postby Ripa » 27 Aug 2018, 10:24
Hi Rern,
if i switch power off the display wich connected to the raspberry goes on and off
how can i fix this?
thanks
Ripa
Ripa
Postby flup2017 » 29 Aug 2018, 19:22
I am having problems installing the MPD upgrade from Addons, after a fresh install of V0.4b_270229 on a 4 GB card on my RPi3 + 7" touchscreen. My workflow was as follows:
* Flash reformatted SD card and boot up, establish WiFi, DAC etc.
* Install Addons menu from command line
* Addons > Expand partition (needed by MPD upgrade)
* Addons > Upgrade MPD
This last step has failed twice and it seems to be a one-way ticket, which is only recoverable by starting the whole process again. I wanted to do the upgrade because currently the RuneUI enhancements' swiping functions to access the library and queue don't work on my setup (although everything else does). I thought I should try Chrome browser to fix this, which requires the MPD update.
FYI, when I type mpd -V I get:
mpd: relocation error: /usr/lib/libssh.so.4: symbol gcry_mpi_ec_decode_point version GCRYPT_1.6 not defined in file libgcrypt.so.20 with link time reference
Any help would be greatly appreciated please. Otherwise I'll have to make do with leaving the top and bottom bars on to access the library, which would be a shame.
Thanks in advance...
Flup
flup2017
Postby rern » 30 Aug 2018, 13:26
@flup2017,
MPD Upgrade was fixed to work with the latest 0.20.21.
Chromium is reportedly somewhat better than Midori but the swipe issue may not be gone.
Is it just on your RPi screen or every devices?
Postby flup2017 » 30 Aug 2018, 18:32
Hi rern - thanks for getting back so quick.
I only really use the RPI touch-screen as I'm slightly old-fashioned. I vaguely recall that the "swiping" worked on my laptop browser though.
Do you mean that I shouldn't run MPD update unless I am already running 0.20.21? Or do you mean that after a successful update I will have 0.20.21? I don't think there is anything special about my configuration, so perhaps other people have had the same problem? If it's any help I can go through the reflash / install process again and post the full MPD update logfile.
Currently I can probably get by with the default MPD packaged with V0.4b, but I'm worried that in six months I won't be able to apply new addons/updates.
F
RPI3, 7" official screen, HiFiBerry DAC+, V0.4beta_20170229
flup2017
Postby rern » 01 Sep 2018, 05:08
@flup2017,
Actually, both MPD Upgrade and Chromium Browser make RuneAudio perform better. If you know how to get back when things gone wrong then go ahead.
The swipe issue:
Both Swipe and Long-press are together from jquery.mobile library.
- Can you do the long-press to toggle items on/off?
Please try the swipe:
- After Chromium installed on current setting
- After reflash SD card with RuneUI Enhancement installed (without Chromium)
Postby Ripa » 03 Sep 2018, 14:58
Rern,
is there a way to make wifi connection more stable FI Spotify
each time it lost connection i use also bupple upnp for tidal and qobus
but it stays the same.
with both wifi and cable
regards,
Ripa
Ripa
Re: [Addon] Addons Menu - Blank screen
Postby erpol » 10 Sep 2018, 14:19
Thanks for this great "addon of addons"!
I just installed it from ssh and all went well, but when I'm on the Runeaudio UI and I go to the addons menu, I just get the page title (Logo+Addons), then below "196 Mb free - 5,31Gb expandable", then nothing at all below. I suppose that's where all the addons are supposed to be displayed, right ?
The Hardware is a Pi3 with a Hifiberry Dac+ card, and Runeaudio is the "official" build from the d/l section of the site, upgraded via ssh. I didn't find any way to assess the exact Runeaudio version from the UI, is it possible ?
I'm using the lot as a "blind" Dlna / Airplay terminal, and it works fine although sometimes unstable and needs reboot.
Any thoughts or help would be great. Thanks!
RP
erpol
Postby rern » 10 Sep 2018, 16:37
Postby erpol » 10 Sep 2018, 17:08
erpol
Users browsing this forum: Bing [Bot] and 17 guests
