Postby rlsten » 26 Sep 2018, 21:28
I tried @popov's steps for getting Addons to work on a Pi 3B+ running the new 0.5b beta. I was able to see the addons menu and install the Rune UI enhancements just as @popov said. Thanks very much for your efforts to get the addons fixed.
Now I could see the UI enhancements fine, and play network files from a synology diskstation. However, I now had another problem: When I tried to update a folder in the library, all I got was a spinning circle, and I could no longer see anything in that folder. I could still play music from other folders, provided I didn't try to update a root or other higher level folder. But any attempt to update any folder resulted in the spinning circle and the loss of the ability to see anything in that folder again. The files were still visible in /mnt/MPD/NAS/mynetworkshare.
I don't know how or why these minor changes to one file could possibly affect the ability to update a network folder, so I have to think it is the UI Enhancements that are somehow causing this. I could update folders before I installed the enhancements on the same image, and after uninstalling the UI enhancements I could update folders with no problem. But when I reinstalled the UI enhancements yet again, I couldn't update any folders--I just got the spinning circle.
rlsten
Postby rlsten » 26 Sep 2018, 22:59
I think I've solved the spinning circle problem when updating folders: It seems that my mpd.db file did not have the correct permissions -- I set them to 777 and now the folders update with no problem.
So to make a long story short: Thanks again to @popov for making the addons, and especially the UI enhancements, viable again.
rlsten
Postby popov » 29 Sep 2018, 21:42
popov
Postby cmh714 » 30 Sep 2018, 02:45
I think rern uses those for the "hide" function of the addons......if a version cant deal or doesnt need that addon, it gets hidden.
or so I believe :)
thanks again popov decent workaround!
Postby cocogex » 30 Sep 2018, 08:45
Thank you popov, I confirm your workaround works perfectly on 0.5 :D !
cocogex
Postby Toube » 13 Oct 2018, 07:01
Toube
Update - Works with RuneAudio 0.5
Postby rern » 25 Oct 2018, 07:59
Postby ianhaynes » 28 Oct 2018, 16:30
Hi Rern,
I'm still getting an error when trying to install the Pause Button addon, "Uninstall file download failed". This on both 0.4b and 0.5b.
Ian
Pi 2, Ver. 0.5b, IQAudio DAC+
ianhaynes
Re: Update - Works with RuneAudio 0.5
Postby Toube » 29 Oct 2018, 08:46
Toube
Postby rern » 29 Oct 2018, 09:26
