Postby Toube » 25 Jan 2019, 19:12
So I re-imaged with 0.5 beta. Gitpulled to latest version. Installed addons.
I installed / expanded partition and after that same error message.
Fatal error: Call to a member function hSet() on null in /srv/http/addons.php on line 31
I'm I the only one getting this?
Regards,
Toube
Toube
Postby cmh714 » 25 Jan 2019, 19:23
Postby Toube » 25 Jan 2019, 20:08
So there is something fishy with the latest addon version?
Any way to revert back to older version or to stop the auto updating for automatically updating the addon?
Edit: Uninstalling the addon from player/dev will render the the whole system unusable. Tried this 3 times and after addon uninstall I have to reflash to get all up and running again.
-Toube
Toube
Postby cmh714 » 25 Jan 2019, 20:16
Postby Toube » 25 Jan 2019, 20:32
Well on a fresh install it will always install the latest update for the addon.
We need a setting for this to be able to comment out the SD.
For now I will not install the Addons, seems to bring some trouble.
Even though the Enhanced UI is pretty cool I can live without it as long as all is working well :)
-Toube
Toube
Postby rern » 26 Jan 2019, 05:18
Postby cmh714 » 26 Jan 2019, 05:41
Postby rern » 26 Jan 2019, 06:58
Update 20190126
Fix loading error.
Postby Toube » 26 Jan 2019, 08:41
Toube
Postby Toube » 04 Feb 2019, 11:57
Hi @Rern,
the latest addons update seems to mess with the playtime numbers color.
Using the normal UI.
- When I hit play button the playtime counter font changes to a dark grey color and there is also an error in the console.
Please see screenshot:
https://imgur.com/CiDmeJ2
Regards,
Toube
Toube
