Postby dynobot » 10 May 2019, 04:36
Hi rern
Yes MPD audio interface shows snd_allo_digione.
Because the Digione is a HAT I turned the HDMI & 3,5mm jack off. Looks like this is the cause of the error, b/c when I turn the HDMI & 3,5mm jack back on the error goes away.
When I run the command I get this
root@runeaudiolivingroom(rw):~# /srv/http/command/refresh_ao
Notice: Trying to get property of non-object in /srv/http/app/libs/runeaudio.php on line 2228
Notice: Undefined offset: 0 in /srv/http/app/libs/runeaudio.php on line 2832
Notice: Undefined offset: 0 in /srv/http/app/libs/runeaudio.php on line 2835
Afterwards;
Launching Addons again still shows the error
Rebooting still shows the error
Looks like the only way to make it go away is to re-enable the HDMI & 3,5mm jack. Either way, functionality everything works fine.
dynobot
Postby rern » 10 May 2019, 04:57
Postby s.k. » 10 May 2019, 06:17
s.k.
Postby rern » 10 May 2019, 14:18
Thank you, @s.k.
The error lines bug was fixed and released.
Postby s.k. » 10 May 2019, 18:05
Thanks for the quick fix/update.
The error lines bug is fixed, I confirm that, but the “Import Webradio” addon now is missing.
s.k.
Postby rern » 11 May 2019, 02:12
Postby s.k. » 11 May 2019, 04:40
By using the RuneUIe, there is a way to mass import radio stations?
s.k.
Postby rern » 11 May 2019, 05:24
Postby porcupiney » 27 Jun 2019, 08:25
Using Runeaudio 0.5 on Pi Zero W.
Coverart fails on an album title with the "%" character in it.
There is an entry in the CoverArt directory, and a matching entry in /srv/http/assets/img/coverarts, but the image does not display.
Dave
Raspberry Pi Zero W; Rune 0.5b; JustBoom Zero HAT
Raspberry Pi B 2; Rune 0.5b; JustBoom HAT
porcupiney
Postby rern » 27 Jun 2019, 15:23
