Postby rern » 10 Nov 2017, 14:17
Postby rern » 10 Nov 2017, 14:27
Postby thanhvo31 » 12 Nov 2017, 03:18
thanhvo31
Postby rern » 12 Nov 2017, 04:59
Hi thanhvo31,
Thanks for reporting.
Something was wrong with the code.
It tried to set expandable status in database without running the expand script but missed and has been fixed.
Please try again. Addons Menu will update itself.
Postby thanhvo31 » 12 Nov 2017, 10:50
thanhvo31
Postby rern » 13 Nov 2017, 05:52
Postby rern » 13 Nov 2017, 06:31
@tuna,
Your is almost ready.
I have add some lines to make it works with RuneUI Enhancement. So please test it by:
Menu > Long-press Addons > fill xortuna in the prompt
Once it's OK. I'll get it online.
Postby thanhvo31 » 13 Nov 2017, 12:51
thanhvo31
Postby janui » 13 Nov 2017, 19:29
Hello thanhvo31,
Rern's Addons do not work with this zero build. Unfortunately, if you install the Addons menu nothing will work. See here: addons-menu-install-addons-the-easy-way-t5370-30.html#p23492 and here: addons-menu-install-addons-the-easy-way-t5370-40.html#p23505.
Postby tuna » 13 Nov 2017, 22:08
Hi Rern,
Seems install/uninstall fine with no files left behind, I can only test on 0.4b however.
One thing to note the install order is dependant on 'ui enhancements' being installed first, not sure if you thought about this?
Cheers for all your help!
tuna
