Postby rern » 14 Nov 2017, 01:51
Postby s.k. » 14 Nov 2017, 09:22
Ok
First time using the new addon
I updated the RuneUI Enhancement and then I installed the Rune YouTube.
The installation was overall successfully although I think I saw somewere the word “error”.
The YouTube button appears in the Q and opens a new window when I press it.
I paste a YouTube video link in that window and after the “OK” nothing happens.
Am I missing something ?
BTW
Nice work guys
Thanks alot !
s.k.
Postby tuna » 14 Nov 2017, 10:57
tuna
Postby s.k. » 14 Nov 2017, 14:20
Hi tuna,
After the "OK" nothing of what you described happens.
I have Frank's latest version (0.4b)
I don't recall any MPC upgrade in the Addons Menu - only MPD upgrade.
Before the final MPD upgrade in 20.11 from rern's Addons, I had manually updated the MPD from 19.xx to 20.6.
Is it possible that this is the cause ?
Anyhow, how I can update MPC ?
Stavros
s.k.
Postby s.k. » 14 Nov 2017, 20:31
-Clean installation of Franks 0.4beta
-Installed Addon menu
-Upgraded MPC
-Installed YouTube
Same result ...
Any idea ?
s.k.
Postby tuna » 14 Nov 2017, 21:49
Hi, could you SSH on and run this command:
tube <Your YouTube url>
E.
tube https://youtube.com/watch?v=oRdxUFDoQe0
And Let me know the output
tuna
Postby s.k. » 15 Nov 2017, 06:27
Hi tuna
From SSH works fine (with an initial delay) - tried various clips.
From GUI nothing :cry:
Question:
How I clear the LocalStorage/Youtube entries ?
s.k.
Postby tuna » 15 Nov 2017, 17:00
tuna
Postby s.k. » 15 Nov 2017, 17:52
It returns “sent songhttps://youtube.com/watch?v=oRdxUFDoQe0
and the file is in the Q.
Maybe something with the import button / command ?
s.k.
Postby tuna » 15 Nov 2017, 22:26
Certainly sounds like it!
Okay, open up rune playlist page, then open the browser debug tools (F12 / Right click -> inspect).
Try importing a youtube video again -
What browser are you using?
Does the "Console" tab of the debug tools show any errors (marked in red)?
And does the Network tab show a call to youtube.php has been made (as below):
tuna
