Postby tuna » 21 Nov 2017, 00:13
Rern - The branch mechanism works brilliantly!
SK - The YouTube addon has now been fixed for 0.4b, it's now in the process or getting approved
I'm hoping the new changes now make it alot easier for me to update and add features, as well as being cross compatible with both versions of rune.
Next I'm going to experiment with streaming from youtube-dl directly into MPD so there's no download delay.
tuna
Postby rern » 21 Nov 2017, 00:39
Postby s.k. » 21 Nov 2017, 05:35
i tested it and it works just fine!
Thanks a lot guys!
Stavros
s.k.
Postby ianhaynes » 21 Nov 2017, 14:53
I had the previous version of the YouTube add-on working on V0.4b without any problems. Having updated, it no longer does anything. I've tried uninstalling and re-installing but no difference. You get the initial dialog to enter the URL but on hitting Import there is no dialog that the file is being imported, nothing happens at all.
Ian
PS: Where you refer to 'MPC' on the Github page, do you mean 'MPD'?
Pi 2, Ver. 0.5b, IQAudio DAC+
ianhaynes
Postby ianhaynes » 23 Nov 2017, 15:46
I just launched the Addon menu and it gave an updating message. When the update had finished it gave me an option to update the Youtube addon, which I did (having previously found that the previous update didn't work on 0.4b).
Unfortunately now the Addon menu itself doesn't work. I've tried uninstalling and reinstalling but this didn't solve it.
How do I get out of this??
Ian
ianhaynes
Postby rern » 23 Nov 2017, 16:06
Postby ianhaynes » 23 Nov 2017, 16:20
Unfortunately that hasn't made any difference. The Addon item on the menu disappeared after uninstalling and reappeared after reinstalling but the menu itself doesn't show when the menu option is selected.
Ian
ianhaynes
Postby FauDrei » 23 Nov 2017, 22:51
FauDrei
Postby rern » 25 Nov 2017, 02:15
Postby ianhaynes » 25 Nov 2017, 12:26
ianhaynes
