Advance Network configuration
Postby clift567 » 27 Dec 2016, 01:51
First would like to thank everyone for the help..
I've moved my runeaudio to the office, and now the network is not showing the Raspberry Pi 3
I believe it has to do with the network authentication. Because, the Pi is not pulling an IP, and even when I set it up a static, I receive a 403 error from the hostname and from the static IP.
Network hardware is 3 Cisco small business smart switches and a Cisco small business router. I have configured the switches with SNMP, QoS, RADIUS, TACACS+, LLDP, and CDP protocols.
To verify, that it is the network, I put a fresh install on the device, with no configuration. I've even set the switches back to Default to up on the network. But nothing seems to be working. Any Ideas, I believe its the SNMP causing the problem\
Also, all connection are ethernet.
From the Debug file:
tcp 66 0 127.0.0.1:80 127.0.0.1:40525 ESTABLISHED 289/nginx: worker p
tcp 0 0 127.0.0.1:56484 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:48950 127.0.0.1:6600 TIME_WAIT -
tcp 0 0 127.0.0.1:56468 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 192.168.1.200:80 192.168.1.152:53853 TIME_WAIT -
tcp 0 0 127.0.0.1:48948 127.0.0.1:6600 TIME_WAIT -
tcp 0 0 127.0.0.1:56509 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56492 127.0.0.1:6379 TIME_WAIT -
tcp 0 1 192.168.1.200:80 192.168.1.152:53855 FIN_WAIT1 289/nginx: worker p
tcp 0 0 127.0.0.1:56528 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56477 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:80 127.0.0.1:40593 TIME_WAIT -
tcp 0 0 127.0.0.1:56503 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56535 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56521 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56463 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56530 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56513 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56502 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56474 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56472 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56511 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56540 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56460 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56539 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56488 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56470 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56481 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56523 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56547 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56496 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56538 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:81 127.0.0.1:51080 TIME_WAIT -
tcp 0 0 127.0.0.1:82 127.0.0.1:52195 TIME_WAIT -
tcp 0 0 127.0.0.1:56482 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56475 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56525 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56458 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56462 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 192.168.1.200:80 192.168.1.152:53848 TIME_WAIT -
tcp 0 0 127.0.0.1:56495 127.0.0.1:6379 TIME_WAIT -
tcp 0 0 127.0.0.1:56480 127.0.0.1:6379 TIME_WAIT -
tcp 66 0 127.0.0.1:80 127.0.0.1:40523 ESTABLISHED 289/nginx: worker p
tcp 0 0 127.0.0.1:56493 127.0.0.1:6379 TIME_WAIT -
tcp 7 0 192.168.1.200:80 192.168.1.152:53850 CLOSE_WAIT 289/nginx: worker p
tcp 0 0 127.0.0.1:56526 127.0.0.1:6379 TIME_WAIT -
clift567
