Airplay distortion over USB
Postby Cyclopse » 02 May 2016, 09:56
I output direct from Rasberry Pi USB to my USB DAC.
Only bug I have is very bad distortion playing Apple Music over Airplay.
I have read the post from Tret that recommends changing one of the lines of code. I am OK accessing the SSH through Putty but am lost from there.
Can anyone list step by step where I go from there to change and save one of the lines of the programme?
Steve
Cyclopse
Re: Airplay distortion over USB
Postby hondagx35 » 02 May 2016, 11:08
Postby Cyclopse » 02 May 2016, 11:18
I am running Pi 2 and Rune version 0.3 Beta. So I just need to input those commands you stated through Putty?
Steve
Cyclopse
Postby hondagx35 » 02 May 2016, 14:32
yes
Postby Cyclopse » 07 Sep 2016, 21:55
Changed to 0.4 Beta for my Pi 2.
Distortion is back when playing Apple Music via Airplay. I have sound on the Meitner DAC, USB input but heavily distorted.
To be honest I have never fully cracked this. When changing the code as follows I get a short click every few seconds;-
ExecStart=/usr/bin/shairport -w –name=runeaudio –on-start=$ON –on-stop=$OFF –meta-dir=/var/run/shairport -o alsa — -d plughw:1,0
I would welcome your input Frank.
Superb project appart from this frustration.
Cyclopse
Cyclopse
Postby hondagx35 » 08 Sep 2016, 08:57
Postby Cyclopse » 08 Sep 2016, 21:35
Amended the entry 4800 to 44100 as advised. Did a reboot and toggled AirPlay in Rune. Tried tonight but no change to AirPlay audio. Still heavily distorted. Should I try a different value?
Cyclopse
Cyclopse
Postby hondagx35 » 08 Sep 2016, 21:49
Postby Cyclopse » 08 Sep 2016, 22:21
The output was;-
closed
closed
closed
closed
closed
closed
closed
closed
closed
access: RW_INTERLEAVED
format: S32_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 64
buffer_size: 65536
Steve
Cyclopse
Postby hondagx35 » 09 Sep 2016, 08:51
Hi Steve,
the "period_size" looks way too low in my eyes.
Let me see how to set this parameter.
