Hi Sif
I tried another time with a new SD card :
[root@runeaudio ~]# cd /boot
[root@runeaudio boot]# tar -xvf RuneAudio-Wakeup.tar
var/www/assets/js/runeui.js
var/www/assets/js/runeui.min.js
var/www/assets/js/vendor/jquery.clockpicker.min.js
var/www/assets/js/vendor/jquery.bootstrap-touchspin.min.js
var/www/assets/css/jquery.clockpicker.min.css
var/www/assets/css/jquery.bootstrap-touchspin.min.css
var/www/command/play
tar: var/www/command/play: Cannot change ownership to uid 33, gid 33: Operation not permitted
var/www/command/stop
tar: var/www/command/stop: Cannot change ownership to uid 33, gid 33: Operation not permitted
var/www/app/wakeup_ctl.php
var/www/app/templates/wakeup.php
var/www/app/templates/header.php
var/www/app/templates/footer.php
tar: Exiting with failure status due to previous errors
you can see two errors in the files copied. why ???
i have double checked the $controllers array i have add a , just after tun as you can see :
'settings',
'sources',
'tun',
'wakeup'
cronie is installed and enable...
I really need help as I am not very comfortable with all this stuff (nor in english
thanks for your help
Pilou007
