Albums are not shown
Postby chatzi » 12 Feb 2021, 14:53
I have just installed the latest rune os
rAudio 1 • 202102121
5.10.13-1-ARCH armv7l
Raspberry Pi 4 Model B Rev 1.4
BCM2711 • 7.6GiB
4 Cortex-A72 @ 1.5GHz
and I have created the db (from my 2tb usb hdd).
It shows that it has 1519 artists, 408 genres etc but no Albums.
chatzi
Re: Albums are not shown
Postby davinci » 17 Apr 2021, 10:37
Same problem. Just updated:
rAudio 1 • 20210416
5.10.25-4-ARCH armv7l
Raspberry Pi 4 Model B Rev 1.1
BCM2711 • 3.8GiB
4 x Cortex-A72 @ 1.5GHz
No albums are shown, everything else is OK, Artists, Genre, ...
The version from end of last year didn't have this problem.
davinci
Postby Ears of Tin » 17 Apr 2021, 11:45
The following worked for me when I did a fresh install this week. Press settings gear icon, next to Library press rotating arrows icon, choose rebuild entire database. This will take some time depending on the size of your collection but it's a one time thing.
Ears of Tin
Postby rern » 18 Apr 2021, 09:42
See .
Postby davinci » 18 Apr 2021, 10:21
Rebuilding the complete library did the trick.
Never assumed that I needed to do so as RuneAudio started building the library after a fresh installation.
Thanks for the tip !!
davinci
Postby Ears of Tin » 18 Apr 2021, 20:44
There is a toggle for "update library on mount" when a new share is created. Next time I do so I plan to turn it off since I will need to do a rebuild after the automatic update. Then maybe only one pass of the data will be needed. 21k tracks takes 3.5 hours over wifi.
Ears of Tin
