Alsamixer
Alsamixer
Postby nic » 05 Jun 2018, 19:43
Just when I was about to start building an active setup using the Piano 2.1 DAC , I can no longer get into Alsamixer . I am using the ip:8080 and getting connection refused . Any ideas what is going on ?
cheers
Nic
nic
Re: Alsamixer
Postby hondagx35 » 06 Jun 2018, 15:48
Hi Nic,
the Alsamixer (Port 80(0) is only available on my latest image.
Did you modify something? Kernelupdate or so?
Re: Alsamixer
Postby nic » 06 Jun 2018, 17:22
Hi Frank , Thanks . I have the latest version running and was able to view the Alsamixer page previously . No changes made to kernel , 4.4.39-A is running .
Edit : It's running 0.4b .
cheers
Nic
nic
Re: Alsamixer
Postby cmh714 » 21 Jun 2018, 16:19
just use the command line....maybe not as elegant but it works.
Re: Alsamixer
Postby grofweg » 24 Jun 2018, 08:23
grofweg
Re: Alsamixer
Postby hondagx35 » 24 Jun 2018, 12:18
Re: Alsamixer
Postby grofweg » 24 Jun 2018, 19:08
grofweg
Re: Alsamixer
Postby janui » 25 Jun 2018, 07:03
Re: Alsamixer
Postby grofweg » 25 Jun 2018, 11:03
grofweg
Re: Alsamixer
Postby hondagx35 » 25 Jun 2018, 17:13
