[SOLVED] Android App: RuneAudio device not found.
Postby chrichri » 12 Mar 2019, 10:35
Hi there,
as the subject says, the android app does not find the RuneAudio server.
My debug info is here: https://pastebin.com/85RC0Wqw
Same behaviour on both a Samsung Galaxy S3 mini (Android 4.4.4) and Samsung Galaxy Tablet T850 (Android 6.0).
I can however access RuneAudio by typing the IP adress in the browser.
Any hints how to the app running?
Thank you in advance.
Best regards
Chris
chrichri
Re: Android App: RuneAudio device not found.
Postby janui » 12 Mar 2019, 12:44
Postby cmh714 » 12 Mar 2019, 16:14
In the app, if you swipe to the right the "Players" menu will appear and you can set the player's IP so the app works.
GL.
Postby J4K » 12 Mar 2019, 20:37
Has this earlier today, uninstalled the app then reinstalled it, problem solved for me.
hth
J4k
J4K
Postby chrichri » 13 Mar 2019, 09:03
the hint, that I can manually register the RuneAudio service solved the problem for me.
To manually register RuneAudio:
- Open the App
- Swipe to the right
- Go to Support and Credits
- Manual Add
- Fill out the IP and Port
Since then, the app is working flawlessly on both smartphone and tablet :)
Best
Chris
chrichri
Re: [SOLVED] Android App: RuneAudio device not found.
Postby cmh714 » 13 Mar 2019, 16:15
Youre welcome! :)
