Apple Lossless m4a - RPi3 - I2S
Postby wieniu26 » 29 Aug 2016, 06:44
I have:
- Runeaudio
- RPI 3 - I2S
- Soekris - (dtoverlay = hifiberry-dac)
Option "FFmpeg decoder plugin" enabled under the Settings page.
Problem playing m4a
I used once MoodeAudio, m4a worked.
I have a lot of music in m4a.
I RuneAudio.
Please help.
RuneAudio debug info:
wieniu26
Re: Apple Lossless m4a - RPi3 - I2S
Postby hondagx35 » 29 Aug 2016, 10:50
Hi wieniu26,
From your debug data i can see that you have enabled DSD-USB.
Please disable DSD, because it only will work with USB DACs.
I did some tests and on my setup (RP3 with HifiberryDAC+) m4a files play without issues.
Please try:
- set MPDs "Log level" to verbose on MENU->MPD.
- try to play a m4a file
- check the log in /var/log/runeaudio/mpd.log
Do not forget to resat the log level to default!
Postby wieniu26 » 29 Aug 2016, 14:12
wieniu26
