Audio Device changes after reboot (XMOS WaveIO Board)
Cubietruck related support
Postby Guitarfreak » 23 Jan 2016, 17:17
finally my WaveIO Board arrived and i tried to get it working with Rune and the Cubietruck.
I can change the Audio Output Interface to "Luckit USB Audio 2.0" which is the WaveIO Board.
I can save and apply, but after rebooting Rune changes back to the default output "sunxi-sndi2s"
Why does it do that?
How can i set the output interface so that it does not change anymore?
Thank you and best regards
Daniel
Guitarfreak
Re: Audio Device changes after reboot (XMOS WaveIO Board)
Postby hondagx35 » 23 Jan 2016, 18:21
Postby Guitarfreak » 23 Jan 2016, 18:57
Hello Frank,
the WaveIO ist powerd by a different power supply and dont need the 5V from USB.
When i reboot the Cubietruck, the WaveIO/Xmos is still powered and working.
So i think delaying the startup would not work.
By the way, when i look in the Settings of mPad The output is still set to "Luckit USB 2.0"
Which part of the Debug do you need?
Its to long to post it here (too much charatcters)
Best regards
Daniel
Guitarfreak
Postby hondagx35 » 23 Jan 2016, 21:27
Postby Guitarfreak » 23 Jan 2016, 23:21
Guitarfreak
Postby hondagx35 » 24 Jan 2016, 01:17
Postby Guitarfreak » 24 Jan 2016, 12:36
Hello Frank i delayed the start to 15, but it still changes the Interface in the RuneUI - but i stays right on the mPad app?
I also got these error message after startup:
"Warning: socket_write() expects parameter 1 to be resource, boolean given in /srv/http/app/libs/runeaudio.php on line 99 Warning: socket_last_error() expects parameter 1 to be resource, boolean given "
Dont know what that means?
Thank you
Best regards
Daniel
Guitarfreak
Postby Guitarfreak » 25 Jan 2016, 21:39
so no solution in sight?
Best regards
Daniel
Guitarfreak
Postby hondagx35 » 25 Jan 2016, 23:25
Postby Guitarfreak » 27 Jan 2016, 21:47
Hello Frank,
would it maybe be possible to just disable the two other outpust of the cubietruck (the i2s and the digital out) would it not be forced to use the Xmos/usb only?
Best regards
Daniel
Guitarfreak
Return to Cubietruck
