Audio GD i2s Output - PS Audio
Re: Audio GD i2s Output - PS Audio
Postby janui » 25 Oct 2017, 14:35
Hi arnaldo,
It is an interesting route which you have chosen to provide a I2S signal with MCK to your PS Audio PWDMK2 Dac. The HifiberryDac+Pro should work as an interface in this way. This module also has audio output connectors and is known for its exceptional price/performance. When you post your photos it would be interesting if you could tell us about the difference in sound quality between the audio output of the PS Audio PWDMK2 and the HifiberryDac+Pro.
Postby arnaldo » 17 Nov 2017, 11:10
UPDATE:
i bought hifiberry digi + pro, i have soldered 5 pins on the i2s out of this card named P4.
i made this map:
1 GND
2 Master clock (22.5792MHz for 44.1, 88.2, 176.4 kHz sample rates, 24.576MHz for 48,96,192kHz sample rates)
3 Bit clock (frequency = 32/64* sample rate)
4 Frame clock (frequency = sample rate)
5 Data
5 -> DATA
3 -> BCLK
4 -> WCK
2 -> MCLK
1 -> GND
from hifiberry digi + pro to audio gd output module
hifiberry digi + pro:
https://support.hifiberry.com/hc/en-us/ ... l-I2S-DACs
http://www.audio-gd.com/Pro/diy/I2Skits/I2SEN.htm
DOES NOT WORK!!
Any idea?
Music!
arnaldo
Postby janui » 17 Nov 2017, 17:36
Hi arnaldo,
Is the hifiberrydacplus pro working without your dac?
Could you post your debug?
Postby arnaldo » 04 Dec 2017, 16:36
Music!
arnaldo
Postby arnaldo » 10 Feb 2018, 20:34
hi guys,
here I am to report my new problem.
I Try to connect my Raspberry to PS Audio Pefect Wave Dac Mk2 in s/pdif using Kali Reclocker and Interface digitale I2S vers SPDIF BNC WM8804.
Kali ok, led blu on.
DAC take the lock.
no sound.
Music!
arnaldo
Postby janui » 11 Feb 2018, 14:56
Postby arnaldo » 14 Feb 2018, 13:54
Music!
arnaldo
Postby janui » 14 Feb 2018, 15:21
Postby arnaldo » 14 Feb 2018, 16:07
Hi janui, you are a good man!
I don't want money back, i think, after many electronics in my life, PS Audio PWDMK2 is a great DAC for the price I had paid.
What I hate is the way of someone to sell products without any tecnical background, in particular his customer care (AudioPhonics) that sold me Kali, AudioGD Module and las i2s - spdif converter.
Thank's for all.
Arnaldo.
Music!
arnaldo
