Audiophonics DAC Sabre ES9023 i2s 24bit/192 - Raspberry Pi
Re: Audiophonics DAC Sabre ES9023 i2s 24bit/192 - Raspberry
Postby hondagx35 » 26 Aug 2015, 14:50
Hi mike,
your debug data looks fine.
So it seems that you have issues with your hardware.
Postby mike » 26 Aug 2015, 20:40
Thanks a million for taking your time to look into my issue. I will try to do a GPIO pintest on my pi (http://wiringpi.com) to see if my dac became a duck or my pi a puck. :lol:
Nevertheless I am amazed by the rune audio system working Out of the box and speedy/comfortable from my smartphone. I am determined to get this running as rune audio and my hifi composition deserves. Probably a better i2s dac than I purchased will do the job with longer life expectancy and less jitter. :idea:
Michael
mike
Postby rayb » 27 Aug 2015, 20:11
Hi Mike
I've been using this DAC for some months now without problems. I left the MCLK line unconnected instead of connecting it to ground - I don't know if this makes any difference.
rayb
Postby mike » 02 Sep 2015, 16:25
Hi all,
The DAC is working again. :P
Apparently linking the MCLK on GPIO grounding pin was not such a good idea. Before reconnecting without MCLK a fresh install of RuneAudio and I2S sound returned.
The sound was much better cause I removed the fan from the Pi. (ripple) No more clicks!!! So PLEASED with 8-) the quality sound coming from the combination.
Final connections for your ease:
from DAC to Pi B+ GPIO;
5V to pin2
PWR GND to pin6 (gnd)
BCK to pin12
MCLK removed
LRCK to pin35
GND dac to pin39
DATA to pin40
Next project: a linear power supply and casing :idea:
mike
Postby mike » 02 Sep 2015, 16:29
Thanks Rayb!! Just saw your reply which was indeed the cause.
Cheers mate :D
mike
Postby spikey1973 » 23 Jan 2016, 00:06
hey guys..
well i finally got my sd card on which i intended to install rune. which i did ofcourse.. install went fine. rather easyly i must say.
i also like the menu of rune.. been hassling with moode last couple of days. I had that installed before on a different sd and i want to keep them both just to compare at a later stage and since i had no time and no extra sd available i decided to wait.. til now.
so my setup is a RPI 2b+ with a Audiophonics I-Sabre DAC ES9023 V2 TCXO Raspberry Pi 2.0 A+ B+ / I2S.
worked out of the box with moode (last time i mention that name ;) )
but i can't seem to get to find it here... as mentioned by rico... only rpi hdmi and headphone thingy.
i expected this.. and new i had to install hifiberry drivers so i went loking on the how to and came here.
so ssh root@runeaudio.local and a few enters on the way i "dtoverlay=hifiberry-dac" the hell out of this thing but nothing happend..
just a blanc new terminal line. nothing else. so i decided to reboot and see if it magically appeared under mpd output config but nothing..
what did i do wrong? according to nico and frank this should have worked.
should i heve sudo-ed? or something?
and on top of that.. i have plugged in my 1 TB samsung evo ssd drive which is for about a 1/10 th full with .flac files.
i can see it mount (lights of the drive blinking). i actually see the message that a usb device has been mounted (or unmounted when unplugged)
but the librairy does not update (no rotating arrows) and i don't see a usb devce mounted under sources..
anyone her that is willing to help me (a rather newby) solve either of these.. rather seperate issues.. so i can start to listen instead of fiddle.
kind greatings.
Matthieu
oh.. almost forgot.
http://pastebin.com/LhrLcXVc
spikey1973
Postby hondagx35 » 23 Jan 2016, 00:24
Postby spikey1973 » 23 Jan 2016, 02:24
ah that's where i could find that... sorry should've been able to locate that myself :(
and the other issue.. i'm afraid it is what you are afriad of. ntfs :D silly me.
anyway to change that without loosing the music on there as far as you know? or can i make changes to any setup file for this to accept ntfs?
thanks in advance!
at least i got some radio music for now.
:D
spikey1973
Postby spikey1973 » 23 Jan 2016, 16:46
spikey1973
Postby hondagx35 » 23 Jan 2016, 18:06
Return to Compatibility list
